NIStune M30 type 2 board
shromySenior Member- 2189
Hmmm, Whats next?
84ZXT -
Bernardd -
Rick88ssSenior Member- 2433
What distributor did you use? You're using it in an L28 inline 6 right?Bernardd wrote: I removed the entire cas assembly and found the z32 guts to drop right in. I had to install a collar to keep it centered and cut a new plug egress hole as it's on the side rather than the bottom.Shiro #443
Bernardd -
So the J30,Maxima DOHC, and Z32 use the same CAS?Bernardd wrote: I used the stock distributor with the J30 or Maxima cas. Yes L28ET engine in my pos.Shiro #443
I started a new thread on using a Z32 ecu with NIStune in a Z31 with a VG30ET
here:
viewtopic.php?f=6&t=25319Shiro #443
340ZXTTAZSenior Member- 108
OK Bernard you've got my attention where can I find a build thread? The Nico Forums?Bernardd wrote: I used the stock distributor with the J30 or Maxima cas. Yes L28ET engine in my pos.
Also Rick the L28ET certain years came with a distributor similar to the Z31 therefore the guts from the Z32, J30, and Maxima should fit, consistently they are have the VG30DE too. -
