NisTune Info (link)
Plug LC-1 in. Set in preferences which com port it's on. open AFR gauge in nistune.
/timeUsual Z31 suspect: Garage Queen (aka broken)
KiileZMember- 76
Okay so I got nistune installed of my ecu. If I want to use the z32 maf do I still need to remove the resistors and what not? Its an 86 NA ecu. -
88sinZSenior Member- 2019
KiileZ wrote: If I want to use the z32 maf do I still need to remove the resistors and what not?
yes -
DMANNSenior Member- 544
I'm thinking about getting Nistune…But, have a few questions.
First I've been with the romulator for quite sometime.
I've got a really good tune now.
Is it possible to just download my tune onto the Nistune and be good to go.
If not what are the other options to keep the tune I have and get it onto Nistune.88na2T-s13,q45 swap 12.6@110mph
87T 2+2 auto,stock -
Russ84naSenior Member- 700
I started using Nistune when it used a Romulator. You did the tune and then burned it onto a chip and inserted in the socket. So I would think that if you have the bin file on the computer you should be able to load it into the nistune software and then upload it to your ecu.DMANN wrote: I'm thinking about getting Nistune…But, have a few questions.
If not what are the other options to keep the tune I have and get it onto Nistune.…and how much HP do you have at 0 boost -
wally1589Junior Member- 2
is there a certain limit in hp, boost, or with nistune type1?
and, can it read any MAF SENSOR? or, is a matter of just connecting the wires of the new MAF?
https://fund-solvaren.com. -
MADMIKESenior Member- 1533
So couple of quick questions:
Can Nistune run a Map setup?
Can you Nistune read 2x Mafs, 2x o2, 2x widebands?DD:
86 Black Turbo 5spd
The Fallen:
Parting Currently:
Garage Sale -
shromySenior Member- 2189
No, no,and No last I checkedMADMIKE wrote: So couple of quick questions:
Can you Nistune read 2x Mafs, 2x o2, 2x widebands?Hmmm, Whats next?
84ZXT -
No not really and yes any maf as long as connected properly. Maf is a big factor to the hp/boost ability.wally1589 wrote: is there a certain limit in hp, boost, or with nistune type1?
and, can it read any MAF SENSOR? or, is a matter of just connecting the wires of the new MAF?Hmmm, Whats next?
84ZXT -
NizmoZ31Senior Member- 208
Is the NisTune chip compatable with a JWT ECU? or worth it or nessecary or a good idea ect, ect…Kira-1988 N/A T-Top- Turbo soon
Naomi-1984 N/A Slicktop R.I.P.-stolen
1976 Chevy Camaro R.I.P.- Custom candycane rods -
sell the jwt get a nistuneNizmoZ31 wrote: Is the NisTune chip compatable with a JWT ECU? or worth it or nessecary or a good idea ect, ect…DD:
86 Black Turbo 5spd
The Fallen:
Parting Currently:
Garage Sale -
Roger that, appreciate it man.
wireJunior Member- 16
Once you have tuned your setup properly with nistune and have a reliable runner, is it possible to pull the changed values and burn a prom to run the ecu with your new preferred tune?
Some classes of racing only allow a stock ecu with nothing extra connected to it but do allow burning a new prom. -
But nothing will be connected to it, it's all inside the ecuwire wrote: Once you have tuned your setup properly with nistune and have a reliable runner, is it possible to pull the changed values and burn a prom to run the ecu with your new preferred tune?
Yes it is possible to do so.wire wrote: Once you have tuned your setup properly with nistune and have a reliable runner, is it possible to pull the changed values and burn a prom to run the ecu with your new preferred tune?
Some classes of racing only allow a stock ecu with nothing extra connected to it but do allow burning a new prom.Hmmm, Whats next?
84ZXT
