The Long-Awaited (by me at least) NA build thread
benz-techSenior Member- 311
My engine is in one piece again!! Trans is even bolted up. Here's a list of some of the specs:
Top to bottom.
Gutted 200sx intake- emissions removed, 60mm T/B
Ported lower intake.
Isky 280deg .485" cams. Morgan's (or knock-offs) cam gears set at 0* now
Ported 85e heads, SS valves JWT springs.
260cc injectors, 7300rpm rev limit. Stock NA tune at present.
10.8:1 BRC pistons. Lightened to 380g (they were 395 and could be lightened another 20g or so but I dont have an end mill) All balanced to within 1g by machinist. OEM rings.
Eagle rods 585g
Entire rotating assy balanced
Nissan OE graded bearings
87 turbo A/T oil pump. ported. Radiused corners of entire oiling system.
5qt gated oil pan and moded p/u
Fidanza flywheel and Centerforce dual-friction clutch
Hand-made, tig-welded equal-length, step-up headers. By Jeff at Teamthump $$$
Hybrid 71B/71C close-ratio transmission. 3.0, 1.8, 1.3, 1.0 .77
Thats about all I can think of at the moment. Now the pics:
edit: a link to a few head pictures. I forgot I started a build thread a while back. Its been that long!
viewtopic.php?f=13&t=17731 -
Guest -
No turbo. And I even preach turbo to the guys asking for more power from their NA cars.300cars wrote: What no turbo?
j/k I like the contrast between the valve covers and headers.
thanks, I had to take pics of the headers now since its ceramic PAINT. $8.00 and 10 minutes of glory, or at least untill it burns off. -
GrrSenior Member- 331
man that is awesome, i hope you can find a lightweight pulley for the front sometime. would probably be a good addition87 Turbo: Stock VG33, stock cams, maxima intake, T5, DXD stage 3 clutch, tubular stainless headers, GT3582r, full 3" stainless exhaust, E85 680cc inj. and Nistune
current time: 13.39@106, 2.05 60' 12psi with old stock 85T motor and street tires! -
NissanXRMASenior Member- 3245
I removed the big chunk of metal used to dampen before it got balanced. Its much lighter than it looks.Grr wrote: man that is awesome, i hope you can find a lightweight pulley for the front sometime. would probably be a good addition -
Headers stick out a bit further. I just set them on for now. Installing this into a 510 involves a dance of headers and an engine being tilted in at 80 degrees or so. Lotsa fun but at least I have the shop and tools to do it in.Careless wrote: nice stepped-tubes. a liiiiiiiiiiiiiiiittle close to the trans, but i'm sure it will work out. -
now all you need is butter's flocked z31 dash in your 510 and your valve covers will match your dash board. LOL.
looks great. low key and nice :-)
dont expect that ceramikote paint to stay on long. it's not that tolerable to weathering. -
Neil86tSenior Member- 1904
I hope that pile of sunken treasure makes more HP than my bolt on 230k tired motor.Elitist Prick Black Z owner.
1986 300zx Turbo
a22770Senior Member- 207
ZFast88ZSenior Member- 1882
Ignoring the nice NA buildup for a second to say, I absolutely love Mercedes Benz workshops.The bullshit stops, when the GREEN light drops.
DeleriousZSenior Member- 6874
Interesting choice on the 10.8:1 pistons, keeping the compression low-ish for reliable daily driving as well or?
1990 jetta vr6'd
