The Long-Awaited (by me at least) NA build thread
That, and whats a 510 weigh? 2000lbs? If that?DeleriousZ wrote: Interesting choice on the 10.8:1 pistons, keeping the compression low-ish for reliable daily driving as well or?- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
Russ84naSenior Member- 700
benz-techSenior Member- 311
Yeah. Clean, brite and freaking AIR-CONDITIONED!!!!!!!!!! Outside temp 100+, inside temp 75ZFast88Z wrote: Ignoring the nice NA buildup for a second to say, I absolutely love Mercedes Benz workshops.
No plans to run it on the bottle. At least for now.
Hope to drop it in thursday night. I am going on vacation for a week, It will be August before it runs. -
I picked 10.8:1 for a few reasons:DeleriousZ wrote: Interesting choice on the 10.8:1 pistons, keeping the compression low-ish for reliable daily driving as well or?
I had an L23 with somwhere around 11-12:1 that pinged like a mother and I just got sick of it.
California gas is crap.
It is a daily driver, although i do have the POS FX-16 to commute in now.
I did the math for the compression calculation. It could be wrong. Its an 11cc dome. I figured if I erred in calculation, I'd rather err on the conservative side.
VG30 combustion chamber shapes are less than ideal.
I bought the pistons before the Shell station down the street from my house started carrying E85. -
I think the length was around 32" could be wrong though. Tubes are 1.5", 1.625" (1 5/8"?) and 1.75"a22770 wrote: The build looks great! What are the tube sizes, lengths, collector sizes? -
a22770Senior Member- 207
That should work perfect for 6100 rpm hp peak, assuming you are in the 260 hp range ( +/- 10hp). -
vinceMember- 67
that looks sweet but be careful you dont burn your fingers on the header when you change your oil filter :-)white 88t vg33 with t3 and alcohol progressive kit from cooling mist (its an auto though)
red 88 2+2 flinstones style -
i doubt he'll be changing oil filters with the engine hot enough to do that, and mechanics gloves and a filter wrench make it a lot easier anyway :Pvince wrote: that looks sweet but be careful you dont burn your fingers on the header when you change your oil filter :-) -
Mitchd03Senior Member- 891
[quote]Careless wrote:These things FTW.Originally posted by vincethat looks sweet but be careful you dont burn your fingers on the header when you change your oil filter :-)
Only problem is I need a smaller one to aid in servicing the tiny tiny hyundai oil filters at work, most of the time I just use these:
look at the shot-glass sized Micra/March K10 filter, since we're Nissan based here.
benz-tech… you have pics of your 510? -
There is a good chance that I've been changing oil filters longer than you've been alive. Thanks for the advice, though. :-Dvince wrote: that looks sweet but be careful you dont burn your fingers on the header when you change your oil filter :-)
The only pictures I have are on this site and on a memory stick somewhere. I'll have to take a few once its running again. I have different wheels on it now
http://www.510garage.com/photos/display … 227&pos=75
http://www.510garage.com/photos/display … 227&pos=74 -
I don't believe so. This car was originally from Bend Or. None of the previous 3 owners is named Ronnie. Same engine bay pictured on teamthump.com- it was 90's splatter paint at the time. Had to change that! -
jamesSenior Member- 978
Loving your Headers very nice work,
I have shared your pain in regard to putting in large engine into a cramped engine bay,
I installed a 1UZ-FE Lexus V8 into an e30 BMW for a buddy of mine, Tail shaft of the gearbox was scraping the concrete floor and the engine hoist was scraping along the roof. Did it all on my own though.
Any pics of what its going into ?
Keep up the good work.85 Turbo Slick Top
Ah nevermind. Almost identical car.benz-tech wrote: I don't believe so. This car was originally from Bend Or. None of the previous 3 owners is named Ronnie. Same engine bay pictured on teamthump.com- it was 90's splatter paint at the time. Had to change that!
Funny enough, also from Oregon. LOL.
