I searched for the info but couldn't find it. I'm looking at just doing the top end untill I drive the car for a while to see what it does. But while I'm doing the heads, what is the max limit for shaving a NA head, for more compression of course... What then would my compression be? NA cam experience/suggestions would be welcomed as well (this will be used A LOT on the street so nothing crazy). I'm running a 500cfm 2 barrel carb with a MSD digital 6 ignition (magnetic pick up on a stock dizzy). I have a set of the stock but modified adjustable cam gears. I also have a 150 shot of NOS. The car weighs about 1,850lbs. Any help would be appreciated.
Minissan ZSX6
240SX rear minus 12" from the center...
Thanks!
Mike
Minissan ZSX6
Thanks!
Mike
