Header Studs
 Cha iro
 at least you gave it a whirl.
 That's the TSB telling you there is updated studs for the VG30. That only applies to VG's with 8mm studs.
 628sxSenior Member 628sxSenior Member- 232
 Also seems like a Nissan saying "You can only use OUR bolts." "So come buy them here."Turbo Rotories… 60% of the time.... they work every time..
 Which is every SOHC VG except the ones with 10mm…which is VG33.NissanEgg wrote: That's the TSB telling you there is updated studs for the VG30. That only applies to VG's with 8mm studs.- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra -
 But i'm tryin them today, so i'll post details.Turbo Rotories… 60% of the time.... they work every time..
 system6Senior Member system6Senior Member- 242
 Just to clear up the confusion from earlier the overall length is 1.75" that is where the 175 is coming from not the pitch.88 z31 tubo auto25spd, 3"TBE, poly everywhere, profec b s2, 60-1, stupid stereo (not 17 anymore), short throw, DXD s4, crushed fpr, FMIC, engloid upper, HK RS-3's sure I am forgetting things but you get the idea.
 08 dakota 5" 33's "cute mods"
 06 g6 gtp - wifey k&n filter
 2x 84 z31 turbo 5spd - parts
 85 z31 turbo auto - parts
 OOOOHHHH lol, yeah that was my confusion. thanx.Turbo Rotories… 60% of the time.... they work every time..
 Oh EFFF! i think they're 1.50 for lengthTurbo Rotories… 60% of the time.... they work every time..
 this is not going well, all 3 heat shield bolts i tried to take off have broken… does everything have to break when i try to fix itTurbo Rotories… 60% of the time.... they work every time..
 DeleriousZSenior Member DeleriousZSenior Member- 6874
 yup. use tons of penetrating lube and even heat to attack those bolts. also, don't just try and twist the bolts off either. impact is almost always better than straight torsion in breaking loose rusted bolts/nuts.
 1990 jetta vr6'd
 I was messing with the header studs today and it seems to be a pitch very close to 1.25. One I had to retap to m8x1.25 and it dug into the metal on the heads when re-inserted but held fine. When I checked the other studs with a m8x1.25 die it would not go through it as the one I re-taped with. Pitches look almost identical next to each other so I don't know.Usual Z31 suspect: Garage Queen (aka broken)
 So turns out the bolts will work fine. dont think i'll get any heat shields back on tho… broke 5 of 5 bolts so far.. All of the studs came out easily tho. In fact some were even already loose :S but im held up for the night with the EGR fitting, damn near welded to the mani.Turbo Rotories… 60% of the time.... they work every time..
 if you can tack weld 6mm nuts onto where the bolts broke on the manifold, you can put the heatshields back on :-)628sx wrote: So turns out the bolts will work fine. dont think i'll get any heat shields back on tho… broke 5 of 5 bolts so far.. All of the studs came out easily tho. In fact some were even already loose :S but im held up for the night with the EGR fitting, damn near welded to the mani.
 [quote]Careless wrote:not a bad idea lolOriginally posted by 628sxSo turns out the bolts will work fine. dont think i'll get any heat shields back on tho… broke 5 of 5 bolts so far.. All of the studs came out easily tho. In fact some were even already loose :S but im held up for the night with the EGR fitting, damn near welded to the mani.
 if you can tack weld 6mm nuts onto where the bolts broke on the manifold, you can put the heatshields back on :-)Turbo Rotories… 60% of the time.... they work every time..
 jamesSenior Member jamesSenior Member- 978
 [quote]michaelp wrote:But you CAN definitly drill and tap your regular old VG30 for 10mm Studs just fine, I got the cylinder head shop to do mine with high quality ARP style M10 studs and they have been great.Originally posted by NissanEggThat's the TSB telling you there is updated studs for the VG30. That only applies to VG's with 8mm studs.
 Which is every SOHC VG except the ones with 10mm…which is VG33.85 Turbo Slick Top
