How bad would it be......
 BLOZ UPSenior Member BLOZ UPSenior Member- 2971
 I'll make a heat shield.BLOZ UP.com
 628sxSenior Member 628sxSenior Member- 232
 Well, yeah maybe, but i took the weather stripping off the top of the firewall, and put a couple washers in between the hood and hinges to vent a little betterNissanEgg wrote: You can run your car without them. You will just have more radiant heat in the engine bay, or heat leak like some people like to say.Turbo Rotories… 60% of the time.... they work every time..
 Hood vent?BLOZ UP.com
 [quote]628sx wrote:Actually behind the hood is a very high pressure zone at speed. So the pressure zone will try to force into the backside of the engine bay with air coming in from front creating hella pressure under the hood (possible hood bulging or fluttering). If you shim up enought so that you have a slight gap on the sides it would work better at "venting".Originally posted by NissanEggYou can run your car without them. You will just have more radiant heat in the engine bay, or heat leak like some people like to say.
 AlloutSenior Member AlloutSenior Member- 182
 how effective would ceramic coating the manifolds and down pipe be?1986 NA - Purchased by me in December 1985
 Working on VG33 - NA to Turbo
 Tokico Illuminas w/ Eibach Springs
 88SS Sways
 It'd cut the heat by a bit. Any heat coating would help, forcing the heat down the pipe to an extent.Turbo Rotories… 60% of the time.... they work every time..
 So instead of heat shields, I just wrapped the manifolds and crossover pipe in header wrap. Also i rubbed red hi temp silicone all over the wrap, because they recommend their silicone spray but it's stupid expensive . pics in the morn.Turbo Rotories… 60% of the time.... they work every time..
