300zr engine?
  • VG30ETT
    VG30ETT
    Junior Member
    • 28
    300zr engine?
    http://cgi.ebay.com/ebaymotors/NISSAN-3 … 6410QQrdZ1
    Think this would fit in a maxima?
  • MrwassmanNA2T
    MrwassmanNA2T
    • 2319
    So that is the VG30DET… Maxima? I am sure you could find a way to make it fit.
    Terrible idea putting those wheels on…
  • craZed
    craZed
    • 530
    That add is full of wrong info.
    imagination is a virtue
  • Andrevas
    Andrevas
    • 1481
    craZed wrote: That add is full of wrong info.
  • G-E
    G-E
    Junior Member
    • 6320
    #5
    0 bids
    so, back on ebay next month then
  • 87-85turbo
    87-85turbo
    • 351
    #6
    what's the reason that engine is so hard to get,limited production?
    87 2by2 na2turbo,AE shell comin soon
  • craZed
    craZed
    • 530
    #7
    Hopfully the buyer knows what he's getting into.
    If it's an s13 owner, he is gonna be pissed.
  • 300zxt
    300zxt
    • 1712
    #8
    The VG30DE was used in some very run of the mill cars over in Japan too like the Leopard, Gloria and Cedric and other family car junkers.
    Oh yeah baby, this thing just screams performance!
    http://youtube.com/c/zcartube
  • 300zxt
    300zxt
    • 1712
    #9
    And cooler! SOHC baby!
    https://cosmeprogramme.org/.
  • SATAN
    SATAN
    • 6782
    #10
    300zxt wrote: And cooler! SOHC baby!
    Ur out ur damn mind son!
  • zed-031
    zed-031
    • 340
    #11
    If you were redesigning the Z31 from the ground up and had the choice between the VG30ET and the VG30DET, which motor would your run and why.
  • SATAN
    SATAN
    • 6782
    #12
    zed-031 wrote: If you were redesigning the Z31 from the ground up and had the choice between the VG30ET and the VG30DET, which motor would your run and why.
    I would run the DET simply because of the fact that you can taylor your LSA the way you want with out having to buy a different grind to do so, You have a higher redline, and you dont have to upgrade all four cams at once. You have more options to play around with. 'Try this on your exhaust cams or try this on just your intake cams. Try this lobe seperation angle, oh that went the opposite of how I wanted well, then try this way. OH you cant because you only have sohc? man that sucks. Well I guess make the best of what you can then.'
  • zed-031
    zed-031
    • 340
    #13
    We can pick up VG30DET half cuts in Australia for US$1500. Comes with gearbox, ECU, loom and MAF.
  • 300zxt
    300zxt
    • 1712
    #14
    DOHC is definately better technology wise, but I think that a SOHC engine that can make snot loads of power definately commands respect! You wont find alot of other SOHC engines that can do the same!
  • G-E
    G-E
    Junior Member
    • 6320
    #15
    300zxt wrote: DOHC is definately better technology wise, but I think that a SOHC engine that can make snot loads of power definately commands respect! You wont find alot of other SOHC engines that can do the same!
    not true, but you won't find many that need as few mods to get there
