Alternate turbo auto oil pump - ITM 057-1084 ?
DougMember- 97
I'm looking for but haven't been able to find a Nissan OE / Atsugi turbo auto pump (p/n 15010-07P02 or 15010-07P03) - ASCO and courtesy parts are out. While digging around I stumbled on what might be an alternate, the ITM 057-1084. Has anyone tried this pump?
Rock Auto lists it for the Z31 as follows:
[pre]ITM ENGINE COMPONENTS Part # 0571084
Automatic Trans; Turbo
http://www.rockauto.com/catalog/more…818&cc=1209541
A google search for the same part number shows an ebay listing where every application is "turbo, auto":
http://www.ebay.com/itm/ITM-057-1084…-/350762275415
[pre]Eng Code VG30T; AT, … 1989 Nissan 300ZX Turbo Coupe 2-Door 3.0L 2960CC V6 GAS SOHC Turbocharged
Eng Code VG30T; AT, … 1988 Nissan 300ZX 2+2 Coupe 2-Door 3.0L 2960CC V6 GAS Turbocharged
Eng Code VG30T; AT, … 1988 Nissan 300ZX Turbo Coupe 2-Door 3.0L 2960CC V6 GAS SOHC Turbocharged
Eng Code VG30T; AT, … 1987 Nissan 300ZX 2+2 Coupe 2-Door 3.0L 2960CC V6 GAS Turbocharged
Eng Code VG30T; AT, … 1987 Nissan 300ZX Turbo Coupe 2-Door 3.0L 2960CC V6 GAS SOHC Turbocharged
Eng Code VG30T; AT, … 1986 Nissan 300ZX 2+2 Coupe 2-Door 3.0L 2960CC V6 GAS Turbocharged
Eng Code VG30T; AT, … 1986 Nissan 300ZX Turbo Coupe 2-Door 3.0L 2960CC V6 GAS SOHC Turbocharged
Eng Code VG30T; AT, … 1985 Nissan 300ZX 2+2 Coupe 2-Door 3.0L 2960CC V6 GAS Turbocharged
Eng Code VG30T; AT, … 1985 Nissan 300ZX Turbo Coupe 2-Door 3.0L 2960CC V6 GAS SOHC Turbocharged
Fr 11/83; Eng Code V… 1984 Nissan 300ZX 2+2 Coupe 2-Door 3.0L 2960CC V6 GAS Turbocharged
Fr 11/83; Eng Code V… 1984 Nissan 300ZX Turbo Coupe 2-Door 3.0L 2960CC V6 GAS SOHC Turbocharged[/pre]
PartsDinosaur.com says:
VG30T Nissan 3.0 OHC New Oil Pump
$124.00
057-1084 -ITM (Not in stock)
VG30T new oil pump, from ITM Engine Components.
This product is made to specs for the pump used on automatic transmission models from 11/1983 thru 1989.
These are becoming scarce, so e-mail me for availability to be certain I can still get it ![/pre]
http://www.store.partsdinosaur.com/page72.html -
yesben13Senior Member- 144
wondering if anything ever came of this? -
shromySenior Member- 2189
In theory it should be the same pump, Someone would need to buy and open it up to confirm.Hmmm, Whats next?
84ZXT -
Did anyone ever buy one of these and check it? They are still listed as turbo auto pumps on Rock Auto.Prius… because Pretentious wouldn't fit across the back of the car…
My 1986 Turbo Build -
I just purchased one as a replacement for the one on SS 820, I'll update when it comes in.
Measurements according to this thread:
http://z31performance.com/showthread…-Auto-Oil-Pump
would indicate that the ITM 057-1084 i got from RockAuto is a turbo 5spd and not a turbo auto.
The outer casting has no identification marks.
Guts:
Inner ring, tooth thickness: .4925
Outer ring, tooth thickness: .4945
Sorry Mario, your turbo auto oil pump is in another castle…
I'd just like to point out that the 1984 new model introduction states all turbo models got high-volume oil pumps, and I myself have owned multiple 100% stock turbo manual cars 84-87 which all measured out to match the high volume pump. So its a weird topic.- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
One of these days I want to order the Melling pump and measure it.- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
Well i'll measure the one out of the SS motor i'm rebuilding and post the dimensions here it for posterity.
88sinZSenior Member- 2019
I'm not going to throw a turd into a pond, but i've seen casting flaws in reliant components to come out with shit quality and false tooling in the casting.
#preinspection
#specsoverbitchez
#fuckzcomisson
Test yo jank, or just run what you slap on the engine.
Your call
#420justblazejesus -
Yeah, I have my misgivings about it after finding its not a Nissan or Atsugi core.
It's an aftermarket casting for sure.
Well I was asking because an aftermarket part doesn't even have to use the same sized gears/bearings/anything as the original… like that other waterpump that comes with a cast impeller… -
This is why I'm curious on the Melling pump. They simply list to use a different pressure bypass spring for auto cars. It could use larger gears than the NA pump, or it may not.Originally posted by G-EWell I was asking because an aftermarket part doesn't even have to use the same sized gears/bearings/anything as the original… like that other waterpump that comes with a cast impeller…- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
or just slap some washers under the spring and measure with a gauge until desired pressure is attainedOriginally posted by michaelpThis is why I'm curious on the Melling pump. They simply list to use a different pressure bypass spring for auto cars. It could use larger gears than the NA pump, or it may not.
