My Next Motor Swap Project
I heard this, yea that does make things easieramreboot;n767600 wrote: AND get this! The crank of the vk56 accepts the flywheel of the z32, no modifications
Some inspiration: https://www.facebook.com/media/set/?set=a.218929391483662.53644.176364502406818 -
Why the Z32 trans? Why not something out of a 350 or 370? Or even something like a 6 speed out of a Frontier?
At least besides the obvious, you already have it.
The Frontier gears are a bit taller through the first few, but you could compensate with the rear end if it was an issue. Not like you'll be lacking in torque.
http://www.300zx.org.uk/gear_ratios.htmFrontier Six Speed Manual Transmission
http://www.vibratesoftware.com/html_…tier.htm#TransDrive First Second Third Fourth Fifth Sixth 2WD & 4WD 4.368 2.518 1.743 1.283 1.000 0.769
Z32 Gear ratios are: 1st 3.21, 2nd 1.93, 3rd 1.30, 4th 1.00, 5th 0.75 for the manual.Prius… because Pretentious wouldn't fit across the back of the car…
My 1986 Turbo Build -
For comparisons sake…
It wouldn't be too far off from the GTO ratios if you geared down at the rear end a bit.The f-body T56 ratios are 2.66/1.77/1.30/1.00/.74/.50. The GTO T56 has a 2.97/2.07/1.43/1.0/.84/.63Prius… because Pretentious wouldn't fit across the back of the car…
stuffertonSenior Member- 467
I imagine part of it is that he already has what he needs for the z32 trans aside from a starter. Plus the z32 30a is known to hold 600+hp, and 5 gears > 6 gears when the final ratios are basically the same.
On a different note, since you are doing this if my VG pops I'll have to figure something out to get a TB48DE over here if I want something nobody has done with a z31 yet.
Build thread http://z31performance.com/showthread…-Paint-done-eh -
andyray187Senior Member- 204
this is awesome alex. not sure if the same power potential is there between the vk and say and ls but awesome none the less -
jamesSenior Member- 978
My Brother in law has fitted one to his brand new jet boat build, does 107 kmh on a 3 stage Hamilton jet no problems.
According to the marine calculations for Jet units it makes it around 400hp. The thing i found interesting is how they don't run a fuel return off the rails. Andy had to tig weld fittings to his so he could run a conventional fueling system to suit his ecu.85 Turbo Slick Top
darryl riceSenior Member- 152
amrebootBanned- 9875
Yeah, its running great!darryl rice;n767875 wrote: Amreboot,
Is the vg33 running ok?
Why you ask? -
Sorry I caught the tail end, we're you putting the v8 in the black z or something esle?!shotyme -
THEBEASTSenior Member- 567
you might have to use a spacer for the z32 flywheel. the starter might have to be shimmed because of thickness differences in flywheels between na and t. the starter is the same between na and t.amreboot;n767600 wrote: Yup. Thats correct.
I already have the z32 trans in my Z now. I still have the z32 bell housing sitting in the garage. So yup, all I need is a z32 starter.
AND get this! The crank of the vk56 accepts the flywheel of the z32, no modifications!
Pretty straight forward! -
NissanEggSenior Member- 5220
The VK56 in the Titan, Armada, and V8 Pathfinder run a constant 51psi from the fuel pump. Nearly all Nissans with returnless fuel system run 51psi.james;n767702 wrote: The thing i found interesting is how they don't run a fuel return off the rails. Andy had to tig weld fittings to his so he could run a conventional fueling system to suit his ecu.
