Bolt in LSX engine mounts for the Z31
  • SATAN
    SATAN
    • 6782
    #16
    That is a fantastic looking motor mount. How far off of the steering rack, does the oil pan sit with these mounts? I set my engine with oil pan on 1/8" steel plate, on top of the steering rack, then built my motor mounts off of that. Just curious how high the engine sits if the next set will drop it a full 3/4".
    Also, how far back does the engine sit? Where is the oil pressure sensor on the back top of the block, in relation to the firewall? I know I have mine crammed as far back as I could reasonably get it.
    EDIT: Actually, I can see it in one of the pics. Looks like it is sitting fairly high. About 1.5-2" above steering rack? Do you guys have any hood clearance issues? Still looks like it would clear everything just fine. But hard to tell until hood is on.
  • nismo kid
    nismo kid
    • 785
    #17
    Thanks for the complement on the mounts John.
    The new set will likely be lowering the the engine another 3/4 of an inch. The end goal is to leave about 3/8 of an inch clearance between the unmodified Camaro oil pan and the top of the P/S rack/crossmember. As far as the sump section of the oil pan its about 1/8 from the P/S rack. Even with this (higher 1st set/prototypes) there is a pretty good amount of clearance between the intake manifold and hood. Here's some pics
    This is all the way back oil pan to crossmemeber clearance
    This is all the way forward
    Here in this pic the engine is all the way back. This is a dirty ass Map sensor on a Ls1 intake manifold. As you can see its very close to the seam on the firewall. So hopefully that will give you a idea of location the oil pressure sensor(in stock location)
    Here's the position of the Right(passenger side) head in relation to the firewall when the engine is all the way back.
    Then here's the position of the Left( Driver side) head in relation to the firewall when the engine is all the way back.
    Sorry I don't have a pic of the hood clearance at the moment, but there's plenty of clearance with the Ls1/Ls6 intake manifold. Once I get the revised set of mounts I will take plenty of pics and report back to update the progress of these mounts. With the engine all the way back there may be some transmission tunnel modification/ massaging that will be needed. It's hard to say considering there's been 5 or so of us that have done/are doing this swap and we all used different transmissions.
    Originally posted by Racinjitter
    :lol: Those of us who say A/C FTW all have a g/f or wife. ac+women=more quiet=possibility of sex. -
    ac+women=SUPER BITCHING=no sex.
  • Wilsonthesphere
    Wilsonthesphere
    • 208
    #18
    I can never go back riding in a poorly insulated z with no a/c in south Florida weather. But Looks like there is enough head room for a whipple charger which I hope leaves the room for adapting an GM ac compressor, relocating the battery and route some new ac lines in it's place. Now were to find all the money to fund this.....
    Own:
    1993 Jeep Cherokee 4X4
    Owned:
    1995 Z32 2+0 NA Black
    1985 Z31 2+0 turbo Black
    1986 Z31 2+0 NA Red
    1988 Z31 2+2 NA Auto
    1984 Z31 2+0 turbo Brown
    1985 Z31 2+0 NA Black
    2003 Nissan frontier D22 supercharded vg33e 4x4
  • 530zx
    530zx
    Junior Member
    • 28
    #19
    Just wondering will you let us know when they go on sale or should I just keep an eye out on dirty dingos site ?
    1999 jeep Cherokee ome lift, JK rubicons on 265/70 general grabbers, rust and some other crap bolted to it wheeler/dailydriver/partshauler/camper
    1987 z31 2+2 5.3 lsx t56 swap in progress and some other things that im to lazy to type in
  • nismo kid
    nismo kid
    • 785
    #20
    I will most definitely be keeping you guys posted of any changes that are made and when they go on sale. Just bear with me lol
  • 530zx
    530zx
    Junior Member
    • 28
    #21
    Ok cool, Sorry if im a Pain lol just getting souped about getting my car done.
  • nismo kid
    nismo kid
    • 785
    #22
    Yeah you and I both man. It's been a long process but we are almost at the finish line.
  • baja12
    baja12
    Junior Member
    • 4
    #23
    did these ever go into production
  • nismo kid
    nismo kid
    • 785
    #24
    I was just notified as of 5:30PM central time. I should be receiving the final/revised version of the mounts sometime early next week. As soon as they arrive I'll be test fitting them. If all is well the 1st batch of the revised mounts will be ready/on sale about a month after next week(Due to the fact they must be made. Then a portion of the mounts will have the available coating applied). Unfortunately the holidays had really slowed our progress down dramatically. But we're back on track. So as before, please bear with me. This is still happening I promise.
    BDG Game.
  • liladair
    liladair
    • 109
    #25
    i am assuming these are designed using an N/A crossmember?
  • nismo kid
    nismo kid
    • 785
    #26
    Please review post#15. But yes it was designed around a N/A crossmember.
  • nismo kid
    nismo kid
    • 785
    #27
    All right guys here's a major update! So I received the revised mounts on Saturday 1/10/15 but wasn't home to sign for them. Today 1/13/15 was the soonest I could make to the post office to pick them up (had work). I installed them and everything fit perfect! So contacted Dirty Dingo to let them know the great news. As of 1:04PM Central time today 1/13/15. They have started production of the Bolt in LSX mounts for the Z31!!!!!!!! They will go sale in about 4 weeks. Keep your eyes peeled here www.http://www.dirtydingo.com/store/index.php or here https://www.facebook.com/DirtyDingoMotorsports for when the mounts hit the shelf. The revised mounts have lowered the engine another 3/4 of an inch. With the engine all the way forward there is 2 7/8in of clearance between the throttle body and hood. Now for some pics.
    Revised mounts
    Revised mounts installed
    TB clearance
    New oil pan Clearance before and after
    Revised mount
    Prototype mount
  • zmyz?
    zmyz?
    Member
    • 47
    #28
    Sweet, glad to see some aftermarket for our cars! Looks like a quality part too…
  • nismopu
    nismopu
    Administrator
    • 2221
    #29
    Wooooot!
  • adamvann3
    adamvann3
    • 4160
    #30
    Looks good. Awesome collaboration
    86na - BlueZ
    85t - Mr Tickles
