CXRacing Intercooler/Radiator kit
kingJunior Member- 19
http://www.cxracing.com/mm5/merchant…Category_Code=
Just wondering what everyone's opinion is on this set up. I would think it would need ducting to be effective but I could be wrong. I'm not a fan of the cheesy BOV either. Maybe i could just ask them to weld a v-band on to run a more quality unit like a Tial, etc. Would the radiator be sufficient? I'll be running a 3.3l and a 60-1 turbo so I'm curious if the set-up would be up to the task.
The only real reason I am asking is because this could definitely save me some money if its an effective set-up. I don't have the means to fabricate anything right now and I'm unsure how much more it'd cost to pay someone else to do it for me. Any help would be greatly appreciated. -
amrebootBanned- 9875
Total junk, crappy crappy.
You're better off making your own kit.
There are definitely plenty of examples of other's builds that you can follow.
You could have a decent setup for around $350. -
Terrible fitment and pipe routing, plus MAJOR heat soaking.
Its not the material they used that makes it crappy, its a terrible setup.
The z31 already produces a good amount of heat, a front mount intercooler is needed, not a worthless V mount.
Plus on top of that, the owner of the company asked the community of our opinion. We all replied back giving honest opinions (bad design), the owner of CXRacing replied calling us idiots.
Not a good way to start a product and have the community support. -
i can understand terrible fitment but is heat soak not an issue when the heat exhangers are in opposite positions? butter and at one time mikeg and even careless ran a horizontal rad. in the nose while having the intercooler mounted almost perpendicularly underneath it. Sorry, im just trying to understand it all. -
Its cool that you are trying to debunk this and figure it at all out.
But there is heat soaking involved. All the real kids run FMICs.
But if you want to buy the kit and try it out, definitely go for it. No one is stopping you
The majority of the z31 community will recommend FMICs though.
Good luck! -
Axel kainModerator- 1221
plus their lack of proper design causes you to loose PS and AC both. plus I think I remember someone who actually DID get one, and had to modify a bunch of their parts just to get them to fit correctly. a FMIC is easy to figure out and do yourself, much cheaper too, than even considering dealing with those guys!Damn dirty angels....these cars!
sigpic -
UrstinSenior Member- 1168
Originally posted by amreboot View PostTerrible fitment and pipe routing, plus MAJOR heat soaking.
This was an ugly day on Facebook lol." I spend another hour trying to rip the bolt out of the subframe, pausing every five minutes to scream and contemplate how I get myself into these situations. Two cars over, a guy urinates. I watch the steam waft off of the fresh puddle in the gravel. It merges with the blowing snow and is cut by the aerodynamic wedge of a nearby Fiero. Beautiful. Another pry and the carrier finally falls to earth. I walk out of there $80 lighter, which makes me more mad." - Brian Kolar -
ozzyrulezSenior Member- 631
Does anybody here even know what their IAT's are (other than us guys running stand alones)? Only way to see if it works or not is to monitor IATs. Though I agree the piping is garbage. -
This is my first time seeing this kit. Doesn't make sense really at all. Most would put radiator horizontal and intercooler as the bottom V. Then cut slots in the hood for all the heat flowing thru the radiator to release out of engine compartment. All that just to cut power steering too…doesn't make sense. I made my intercooler kit for ~ $300 with all cutting and welding. Intercooler was $100. Piping kit was like $120 and sat in a industrial welders parking lot for a few hours testing fitting and welding. Cost me $80 bucks for him to weld the stuff up in between the real jobs he was doing.
Will save you a lot of time and pain just go do front mount which will be more than enough for what you are doing I'm assuming.
With this kit you will be spending more time building shrouds and re-arranging things than it's worth.Usual Z31 suspect: Garage Queen (aka broken)
88sinZSenior Member- 2019
Originally posted by amreboot View PostPlus on top of that, the owner of the company asked the community of our opinion. We all replied back giving honest opinions (bad design), the owner of CXRacing replied calling us idiots.
Gonna need a link for that, i love stupid dramaOriginally posted by UrstinThis was an ugly day on Facebook lol.
