mario88ss wrote: Do they make ARP exhaust manifold studs? When I took my heads out to get work done I had 6 broken studs. I have a new set of stock ones but if ARP makes them I will like to know how much they are.
ARP Hardware part #'s
Re: ARP Hardware part #'s
mario88ss wrote: I got my ARP HEAD Stud part #'s (I know this work for sure.)
M5-100-1LB for the Short Stud
AM5-900-1B for the Long Stud
AMW-750N for the washer
AMN-12-1 for the nutJukka Kivinen - Europe / Finland - '88 Turbo 2+2 Targa
[quote]Kennedy wrote:Originally posted by mario88ssI got my ARP HEAD Stud part #'s (I know this work for sure.)
Does anyone have that 7 digit part# for those?
AM5-100-1LB - Short Stud (18 needed) - $6.43 each = $115.74
AM5-900-1B - Long Stud (8 needed) - $7.56 each = $60.48
AMW-750N - washer (26 needed) - $.92 each = $23.92
AMN-12-1 - nut (26 needed) - $4.15 Each = $107.90
Total cost = $308.04
Jason84NA2T wrote: I don't understand... these are the ARP part numbers:
http://www.arp-bolts.com/Catalog/Catalo ... atalog.pdf
Like 202-6003 for rod bolts.
They say that those are not part numbers. Just names.Jukka Kivinen - Europe / Finland - '88 Turbo 2+2 Targa
[quote]Kennedy wrote:Originally posted by Jason84NA2TI don't understand... these are the ARP part numbers:
Finnish retailers need part no. that are in ARP catalog .
BLOZ UP wrote: The stock head bolts are not stretch bolts, but if you are using the original ones that came with the car, I would buy a new set.85 Z31 6.0 LSX turbo 766whp/792wtq
[quote]SATAN wrote:Originally posted by BLOZ UPThe stock head bolts are not stretch bolts, but if you are using the original ones that came with the car, I would buy a new set.that just means ur not torque'n them hard enough LOL
Wicked.. I just got few prices.
(ARP Connecting Rod Bolt Kits)
ARP 202-6003 KK-PULTTISRJ NISS 87.00e -> $110 [in Summit $51.88]
(ARP Main Stud Kits) ->
ARP 202-5402 PINNAPSRJ RUNKOL 149.00e -> $190 [in Summit $89.88]
236.00euros -> $300 [in Summit $141.76]
Cheap eh?
If i order from summit. I pay maybe $200 including shipping (International order pay $24 extra). When they arrive here i pay 4.7% customs for engine parts and %22 for taxes.
That would get me $253. Only $50 difference :roll:
And is someone in usa buys them and sends me cheaper i might same more.. (more eBay reading)Jukka Kivinen - Europe / Finland - '88 Turbo 2+2 Targa
[quote]grahfz wrote: [quote=Jason84NA2T]Originally posted by SteveZ31After I bought mine I called ARP and told them that the above said part numbers made up a kit for our Motor, the represenative I spoke to kind of just blew me off.
I just called and got the same thing; a flat "no". Essentially what he explained is there is not enough demand for a kit to be made for our application. They like to engineer each kit to an application, whihc would mean getting the actual engine in question and installing the parts to say something beyone "it fits and holds the head on there". Can't say I blame them, he said they are always willing to sell the bits individually if you ask by part number.
Final part numbers and prices from ARP:
Total cost = $308.04Originally posted by SteveZ31how about just using the long studs? it'd give you the nice studded head ability of laying the gasket on and then sliding the head down into place.
and not be as hard to clean around the next time you have to change gaskets.
not to mention 1/3rd the cost.
any body know how much torque our vg heads needs with arp studs
Thanks1988 SS TURBO BEING RESTORE.
Jason84NA2T wrote: Yes. I have them and they are correct. Our engines use the same ARP main stud kit as the SR20, so don't be suprised when the box says SR20 on it.
This information is in the turbo faq.85 Z31 6.0 LSX turbo 766whp/792wtq
[quote]jn1cz wrote: [quote=grahfz][quote=Jason84NA2T]Originally posted by SteveZ31After I bought mine I called ARP and told them that the above said part numbers made up a kit for our Motor, the represenative I spoke to kind of just blew me off.
Any consensus on whether there's really much benefit in this? Doesn't seem like the clamping force would be improved much overall and isn't there dowels to hold the gasket in place while installing the heads?
well I couldn't find any info on how much torque to give the ARP head studs. Sow I put them at 75 using the ARP assembly lubricant.1988 SS TURBO BEING RESTORE.
mario88ss wrote: well I couldn't find any info on how much torque to give the ARP head studs. Sow I put them at 75 using the ARP assembly lubricant.
Also ARP studs are designed to streatch and the stock bolts are not. Somthing Dweezil forgot to mention but i'm sure he knew.85 Z31 6.0 LSX turbo 766whp/792wtq
