Have to tear the motor down for rebuild..
  • grahfz
    grahfz
    • 310
    I've lost ~30psi compression (some worse, some less) across all six… still acceptable compression, but in the little bit of mileage I've put on this motor between tests, not acceptable.
    It's getting lots of blow-by. Smoke coming out of the valve-covers and blowing the dipstick out. I can feel the engine pulsing through the covers as well.
    Burns oil as soon as you start it as well… fouling out the plugs too.
    And it's also developed a rod-knock. pretty badly too.
    All of this is pointing at something in the oiling system, to me.
    so, 15k miles on this engine, and it's down for a rebuild.
    2009 370z touring/nav/sports
  • t70
    t70
    • 104
    OUCH!!! That's awfully depressing.. I didn't replace the oil pump in the vg30 when i built it -- hope it doesn't bite me in the ass. I would have replaced it but my poor buddy who owns the car was expecting to spend much much less than he has so far.
    eagle rods
    38 mm external wastegate
    mild port/polish
    3 angle valve job
    custom intercooler piping
    rad moved back
    romulator
    420cc injectors
    walbro 255lph in-line fuel pump.... and lots of headaches… lol
  • G-E
    G-E
    Junior Member
    • 6320
    how was oil pressure? aside from oiling problems like sludge or blocked passages, was everything cleaned/flushed before?
    there's first of all no way 15k should wear out rings so much to have blowby.... but having excessive blowby does cause a bit of oil cooking, especially where there isn't that much
    also I'd really like to know if you you were running hot/lean
    buy feminized seeds USA.
  • grahfz
    grahfz
    • 310
    I put a HP/HV pump in it when we built it.
    Oh, I'm adding it up, and I'm going to have another 2-3k in it by the time that I'm done.
  • grahfz
    grahfz
    • 310
    #5
    G-E wrote: how was oil pressure? aside from oiling problems like sludge or blocked passages, was everything cleaned/flushed before?
    not running hot/lean at all. Only 4-6psi of boost w/ a walbro. shouldn't have been a problem, plus I was watching the LM-1.
    Oil pressure, is still well above FSM specs.
    the whole engine was pretty much new.. but yeah, we tore it down and had it cleaned.
    *edit* as an addition.. the compression tester was coming back with good amount of oil on it from some cylinders.
  • BLOZ UP
    BLOZ UP
    • 2971
    #6
    rings may not have seated right…
    BLOZ UP.com
  • MrwassmanNA2T
    MrwassmanNA2T
    • 2319
    #7
    BLOZ UP wrote: rings may not have seated right…
    unfortunatly, sounds like it
    Terrible idea putting those wheels on…
  • grahfz
    grahfz
    • 310
    #8
    motor was perfect until the upgraded turbo. Hell, during that whole ordeal, I tested compression, averaged ~181psi
  • G-E
    G-E
    Junior Member
    • 6320
    #9
    try nissan rings this time? heh
  • grahfz
    grahfz
    • 310
    #10
    heh, they were nissan rings.
  • G-E
    G-E
    Junior Member
    • 6320
    #11
    then all I can think is you didn't break it in properly
  • j30_vg33et
    j30_vg33et
    Member
    • 62
    #12
    I've got some spare Total seal rings laying around here for sale… Didn't use them cuz file to fit was just tooooo much of a PITA.
    It's RWD in reverse.
  • t70
    t70
    • 104
    #13
    it's not that difficult.. i just use a ring file… takes about an hour to do all the rings perfectly. Less time if you've done it before… took me an hour to file fit and assemble the bottom end of a 4g63.
    eagle rods
    mild port/polish
    3 angle valve job
    rad moved back
    romulator
    420cc injectors
  • grahfz
    grahfz
    • 310
    #14
    G-E wrote: then all I can think is you didn't break it in properly
    I'd say ~15k miles is broken in.
    Thanks, but I'll get them with the pistons.
  • j30_vg33et
    j30_vg33et
    Member
    • 62
    #15
    If you call Beeri at Arias he's already got a set of +0.5mm VG33ET 8.5:1 compression forged pistons designed. They use the 21mm stock rod pin diameter too, which is nice. The pins is tool steel, and narrowed for weight.
    On my set, there's never any piston clatter. Also, clearly, I had them coated at Swain, which isn't included in his price.
