Have to tear the motor down for rebuild..
t70Senior Member- 104
phew! man.. that kinda scared the crap out of me… I thought it a bit weird that there wasn't any mention of oil squirters in the haynes manual. That's a huge relief.8.5 custom arias pistons (.020 over)
eagle rods
38 mm external wastegate
mild port/polish
3 angle valve job
custom intercooler piping
rad moved back
romulator
420cc injectors
walbro 255lph in-line fuel pump.... and lots of headaches… lol -
TurboZkidSenior Member- 395
this might sound stupid..but im new does this piston setup require boring…and how much if so?j30_vg33et wrote: If you call Beeri at Arias he's already got a set of +0.5mm VG33ET 8.5:1 compression forged pistons designed. They use the 21mm stock rod pin diameter too, which is nice. The pins is tool steel, and narrowed for weight.
On my set, there's never any piston clatter. Also, clearly, I had them coated at Swain, which isn't included in his price.
grahfzSenior Member- 310
yes, too much for a vg30 block. should be fine on a vg33.
consult your machinist.vg33et -blew some chunks outta it, then gave it all away.
2009 370z touring/nav/sports -
cheezmontaSenior Member- 384
Kind of off topic a bit. About the oil squirters.
Has anyone actually tried to put them in on a VG30E(T)? I was looking at my buddy Scot's torn down VG30DE and it just looks like they're tapped into the main oil galley. Seems simple enough to have the machine shop do.
Also was reading up on the oil squirters a bit. The VG30DE(TT) all used a small diameter open squirter but the SR20 uses a small check valve squirter that only lets oil squirt above something like 25-28psi. I assume for when the motor is building more oil pressure due to higher revs aka racing.
I'm about a year (fingers crossed) from tearing into my motor to do any hands on with this but maybe someone with a block ready for machine work would be interested.
