Opinions on t72
enjoyrthSenior Member- 468
Opinions on t72
So I was able to pick up a turbonetics t72 for a pretty decent price and I wanted some opinions on it. It is has a .70 A/R cold side with a 72mm wheel, and a .85 A/R hot side with a p-trim wheel. Any educated opinions will be appreciated.
440whp on pump fuel and the STOCK MAF -
Shady195Senior Member- 679
It probably wont spook till 4k+ Rpm…enjoyrth wrote: So I was able to pick up a turbonetics t72 for a pretty decent price and I wanted some opinions on it. It is has a .70 A/R cold side with a 72mm wheel, and a .85 A/R hot side with a p-trim wheel. Any educated opinions will be appreciated.
Great turbo if your going for bigg numbers..
Sell it for profit.. buy a more suitable turbo1989 300ZX 2+2 N/A GLL
Auto to Manual Swap
NA2T Complete
I currently have a t64e, which has a .60 A/R compressor housing with a 66mm wheel. I feel that this is where I am getting choked up. It has a p-trim wheel as well, so I will be using the exhaust housing from the t64e (which I was told was a .63 A/R, but I am pretty sure its a .85 as I don't hit full boost til 4500+) as to avoid having to make a new downpipe. I have no problem with my current lag. I made 440whp on this turbo, and I am looking for an upgrade. I am obviously looking for big numbers and am not afraid of making real power with a real turbo, which results in dealing with some lag.
Andrew84zxSenior Member- 1110
[quote]Shady195 wrote:Originally posted by enjoyrthSo I was able to pick up a turbonetics t72 for a pretty decent price and I wanted some opinions on it. It is has a .70 A/R cold side with a 72mm wheel, and a .85 A/R hot side with a p-trim wheel. Any educated opinions will be appreciated.
have you ever ridden in a car with a turbo that big? i have ridden in cars with comparable size turbos and the lag is not as bad as you think. this is the mindset of most z31 guys, that's why there is not many fast z31's out there. my buddy runs a 67mm in his evo and that's a 2.0 liter!!! he drove that car everyday for about 6months until he got a beater.
rick, i think it will be a good turbo for what you wantI hate wheel gap with a extreme passion
my build
viewtopic.php?t=2755
seller feedback
viewtopic.php?f=18&t=10430 -
New 2 ZSenior Member- 1219
it's a 3 fucking liter engine. use it.
Rick88ssSenior Member- 2433
The 440whp was made at 22psi. The t72 has a .70 A/R compressor housing.Rick88ss wrote: At what boost are you making 440whp? What size compressor housing does the T72 have?
onefast87Senior Member- 696
i also have a T72,but i chose to use the 0.70 hotside.
some say it might be too big, but i think as long as you have the supporting mods, it should be no problem.
PICS?http://www.youtube.com/user/onefast87 -
I think you will have comparable spool to your t-64, maybe 1-200rpm difference.
SATANSenior Member- 6782
A P trim wheel with a .85 a/r (P-85) for the hot side, is pretty damn small for a 72mm inducer compressor wheel. Meaning, IMO the compressor wheel is too large for the turbine wheel and housing.
You will make great power and it will spool quick for the street. However, if you are planning on running the T72 to its full potential, then your back pressure is going to be very high while the turbo is maxed out and might not even max out at all due to too much restriction in the hot side.
If you don't plan on going past 600whp with it, I say leave it. It will run great. If you do go for larger HP numbers, just get a bigger A/R on the back side. By larger I mean something over a 1.00. Then you will start to see some noticeable lag, but even still not THAT MUCH.85 Z31 6.0 LSX turbo 766whp/792wtq
This is exactly what I wanted to hear. I like this turbo choice because it offers me exactly that: the chance for a streetable turbo with less lag while I keep nistune, and then the option to go bigger once I get around to it.SATAN wrote: A P trim wheel with a .85 a/r (P-85) for the hot side, is pretty damn small for a 72mm inducer compressor wheel. Meaning, IMO the compressor wheel is too large for the turbine wheel and housing.
i think turbonetics sells a T3/T4 turbo that can get you up to 500hp
hypcodiiihopSenior Member- 1312
tons of people sell turbos that can get 500hp pending your setup. your point in sayin that to me is....misquote?Four Doors for More Whores -
DMANNSenior Member- 544
The spec on that turbo ain't that bad!!!
I have a hx40 with almost those same specs and I get full spool at 3500-3800rpms!
I also still have lots left for the big-end!88na2T-s13,q45 swap 12.6@110mph
87T 2+2 auto,stock -
[quote]Andrew84zx wrote: [quote=Shady195]Originally posted by enjoyrthSo I was able to pick up a turbonetics t72 for a pretty decent price and I wanted some opinions on it. It is has a .70 A/R cold side with a 72mm wheel, and a .85 A/R hot side with a p-trim wheel. Any educated opinions will be appreciated.
Yes I have..
No it dident fully spool till about 3800-4000rpms
Like I said great turbo if hes going for big numbers like satan said 600+whp
if thats what he wants then its a perfect turbo1989 300ZX 2+2 N/A GLL
Auto to Manual Swap
NA2T Complete
