Opinions on t72
enjoyrthSenior Member- 468
There are much more mature and tactful ways of getting your opinion out (there are also better venues, the dyno thread, for example).
Back on topic. I should have some pics of the turbo up later tonight, hopefully installed :lol:
440whp on pump fuel and the STOCK MAF -
Again, back on topic: It turns out this is actually a Q-trim T72. The previous owner had bored out a P-trim turbine housing and was using that. I am going to need to find a t4 Q-trim housing with an appropriate A/R, or just go ahead and bore out my p-trim housing. Any opinions on this?
SATANSenior Member- 6782
I deleted all the useless shit in this thread. Please do not bring it back. If you have a problem with what I deleted…PM me.85 Z31 6.0 LSX turbo 766whp/792wtq
Thank you John. I was really hoping you would give me your opinion on the Q-trim. I was planning on boring out the P-trim housing and using it....SATAN wrote: I deleted all the useless shit in this thread. Please do not bring it back. If you have a problem with what I deleted…PM me.
[quote]enjoyrth wrote:To be honest, I have no experience with the Q trim wheel. I can tell you just from a logical point of view, it would be better suited for that 72mm comp wheel though. If you just bored out your housing with that Q trim, it would still probably be a fairly OK street setup still and would obviously breath better. Since I don't have the experience with the Q trim though, I can't say 100% it would be an ok street setup.Originally posted by SATANI deleted all the useless shit in this thread. Please do not bring it back. If you have a problem with what I deleted…PM me.
I ran the P trim wheel on a .8x housing with my T66. That was a good match and gave me a pretty damn good street car but, your 72 is 6mm larger, so… again, to use it to its full potential, you are going to be choking it out with that p trim hot side setup.85 Z31 6.0 LSX turbo 766whp/792wtq
miloSenior Member- 356
onefast87Senior Member- 696
after reading this post i decided to do some measuring, it turns out i also have a Q trim T72.
i think i am going to sell the 0.70 hotside and get the 0.81 or 0.96, what do you guys think?
my car will remain driven on a regular basis. also i just noticed that housings available for this T72 only come in 3" vbands, no 4".http://www.youtube.com/user/onefast87 -
FlawleZSenior Member- 1971
I would go with the .81. The .96 isn't necessary on a street driven car unless you don't mind much more lag. The .81 will still have no problem flowing ~800 whp.onefast87 wrote: after reading this post i decided to do some measuring, it turns out i also have a Q trim T72.
my car will remain driven on a regular basis. also i just noticed that housings available for this T72 only come in 3" vbands, no 4".545 RWHP & 540 RWTQOriginally posted by Andrew84zx
sprtcrazy17Senior Member- 1685
