Aftermarket Tie Rods and Adding More Angle
PaulsMember- 64
Ok. I get it now, it's a decent learning curve, however I don't agree with the negative cant be done attitude.
exploring s14 setup has helped me get my head around this.
Looked into z32 which is freakish setup.
So going back to z31 hubs & knuckles, goal is to test fit my 08 g37s rotors and get caliper adaptor made up for the same aekbono callipers.
Next will be adaptor that slides into cut down z31 tube that has holes to bolt upto s14 coilovers.
i just hope spindles are the same!Love z31's as much as I do? Check out my build: http://www.zdriver.com.au/index.php/…__80#entry2219 -
Why don't you make your own thread to talk about it, rather than hijacking this one?
Powered by Fund Solvaren.Prius… because Pretentious wouldn't fit across the back of the car…
My 1986 Turbo Build -
PaulsMember- 64
Sorry dude, started with tie rods and as usual the problem was deeper ending up at spindle, hubs etc.jaqattack02;334595 wrote: Why don't you make your own thread to talk about it, rather than hijacking this one?Love z31's as much as I do? Check out my build: http://www.zdriver.com.au/index.php/…__80#entry2219
