EXACTLY, too often the wrong things have been done by people with long and illustrious credentials, who are too stubborn to admit they screwed up…OK85ZX wrote: which is why I said what I did. If the installer just made a mistake I see no reason for him to have brought his credentials into the conversation. -
Rambo69Member- 92
Reason behind the "inverted" bushing is get as low as possible. We have made additional mods to the stock Z frame rails to accommodate this as well, also we are using the OEM washers that would normally be on the S14 to sandwich everything together.sigpic
NWN Moderator
FertilePower on XboxLive -
Someone correct me if I'm wrong, but wouldn't the "inverted" bushing make the ride height higher instead of lower as your subframe is now gapped off the chassis by the actual bottom of the bushing?
the coilovers lower the car, changing the angles of every arm… raise the subframe and it would be like raising the carRB20ZR wrote: Someone correct me if I'm wrong, but wouldn't the "inverted" bushing make the ride height higher instead of lower as your subframe is now gapped off the chassis by the actual bottom of the bushing? -
[quote]G-E wrote:But if you raise the subframe in relation to the ground it would tuck it up more effectively making the car lower. If you have that 1/2" of the bushing spacing between the chassis and subframe then you lose that 1/2" of extra lowering (if you go that low) that you would get from coilovers. The bushings are intended for S-chassis, so why not install them the way they would fit on an S-chassis that isn't running coilovers? Just my 2 cents.Originally posted by RB20ZRSomeone correct me if I'm wrong, but wouldn't the "inverted" bushing make the ride height higher instead of lower as your subframe is now gapped off the chassis by the actual bottom of the bushing?the coilovers lower the car, changing the angles of every arm… raise the subframe and it would be like raising the car
ButterSenior Member- 1519
Guys, the subframe has no bearing on the ride height. But if you don't tuck it up as far as you can to the chassis, the angles on all the arms will not be desirable. Especially, on a lowered car.sigpic -
That's right. I'm being full blown today. Long story short tho, they have an intended orientation for a reason. If it was better to install them upside down, everyone would.Butter wrote: Guys, the subframe has no bearing on the ride height. But if you don't tuck it up as far as you can to the chassis, the angles on all the arms will not be desirable. Especially, on a lowered car.
MADMIKESenior Member- 1533
/Threadjack/
Is anyone using Stance GR+ Pros?
/End ThreadjackDD:
86 Black Turbo 5spd
The Fallen:
Parting Currently:
Garage Sale -
adamvann3Senior Member- 4160
I doMADMIKE wrote: /Threadjack/
/End Threadjack86na - BlueZ
85t - Mr Tickles -
Rambo69Member- 92
[quote]adamvann3 wrote:SameOriginally posted by MADMIKE/Threadjack/
/End Threadjack
I dosigpic
NWN Moderator
RXGhostSenior Member- 510
I am also1984 300ZX - 1988 VG30T Engine, Trans, Diff, ECU
badboyz31Senior Member- 2403
I got GR+ Pro SS-D's with 12k springs front and rear with helpers!1uz Swapped, lowered, flaked out '86 z31
1sikzSenior Member- 1074
badboyz31 wrote: I got GR+ Pro SS-D's with 12k springs front and rear with helpers!
You have them, or you have them in the mail?Originally posted by adamvann3Hmm I normally jack off my rear x-member. -
[quote]1sikz wrote:they are in the mail, same difference :nanan?reOriginally posted by badboyz31I got GR+ Pro SS-D's with 12k springs front and rear with helpers!
it was a very vague question hahaha1uz Swapped, lowered, flaked out '86 z31
Yeah, I was just messing with you. I've been waiting for my euro bumper lights that were "shipped out" in late January.Originally posted by adamvann3Hmm I normally jack off my rear x-member.
