badboyz31Senior Member- 2403
the other guys made some sort of doohicky that fixes the problem, me I just left it the way it is, and if it binds it binds. I will probably find a spare set of uprights and cut the mount off and re-weld them later!1uz Swapped, lowered, flaked out '86 z31
The Q45 rear subframe is too wide, it's actually wider then a tt Z32 subframe.
Spooledup300z wrote: So you use a Q45 rear subframe? I thought z32/Q45 was to wide for the Z31.
This is basically what Iâm looking to do..
Was going to use the Q45 knuckles, Z32 struts, and see if the Q45 rucas are usable as they are half moon.
badboyz31 wrote: this is his setup, just like mine and a few others
s13 subframe
q45 diff
1 q45 axle
1 z32tt axle or skyline axle
s13 diff cover
j30 half moon rucas
z32 or q45 uprights
and a few other tad bits here and thereKevin
[quote]K_Scheeringa wrote: The Q45 rear subframe is too wide, it's actually wider then a tt Z32 subframe.
Originally posted by Spooledup300zSo you use a Q45 rear subframe? I thought z32/Q45 was to wide for the Z31.
badboyz31 wrote:actually to be honest I think my rucas are from the q45 and not the j30!Originally posted by Spooledup300zthis is his setup, just like mine and a few others
s13 subframe
q45 diff
1 q45 axle
s13 diff cover
j30 half moon rucas
z32 or q45 uprights
https://fund-solvaren.com.1uz Swapped, lowered, flaked out '86 z31
[quote]badboyz31 wrote: [quote=K_Scheeringa]This is basically what Iâm looking to do..
Thats good to hear.. I'm hoping to use most of the arms from the Q45 as the S13 sub frame i got as seen better days, but once i get into it I'll compare measurements between parts.. Now all i have to do is find that dam drivers side axle..Originally posted by badboyz31this is his setup, just like mine and a few others
s13 subframe
q45 diff
1 q45 axle
s13 diff cover
j30 half moon rucas
z32 or q45 uprights
actually to be honest I think my rucas are from the q45 and not the j30!Kevin
[quote=badboyz31]the other guys made some sort of doohicky that fixes the problem, me I just left it the way it is, and if it binds it binds. I will probably find a spare set of uprights and cut the mount off and re-weld them later![/quote
Check Zilva when you choose to weld it, takes a serious Tig machine over 250 amps to weld that thick aluminum. You may be better off modding the shock tower87T, My build thread http://z31performance.com/forum/z31-…lee-s-87t-rb26 -
[quote]Spooledup300z wrote:oh i would not be welding it, I would take it somewhere and have them weld it!Originally posted by badboyz31the other guys made some sort of doohicky that fixes the problem, me I just left it the way it is, and if it binds it binds. I will probably find a spare set of uprights and cut the mount off and re-weld them later
Build thread http://z31performance.com/showthread…-Paint-done-eh -
didn't want to go through 24 pages right now but since this is done and I missed it any change there would be another group buy for this again? -
I actually think I found something the would really help with the angel of the mount as they replace the bushing with spherical ball joints! I'm gonna give them a try and see if they would help angle them better!
http://www.importpartspro.com/splrsbz32.html1uz Swapped, lowered, flaked out '86 z31
It wouldn't help you, 240 guys have a tried that route, only way to solve this issue as I stated before. Is to either modify the upper shock mount, or cut and re-weld the rear lower mount. The advantage of running the z32 rear knuckle is weight saving of like 5lbs.badboyz31 wrote: I actually think I found something the would really help with the angel of the mount as they replace the bushing with spherical ball joints! I'm gonna give them a try and see if they would help angle them better!
It's so much easier to just swap the bearing/hub, rear E-brake assembly into the rear 240 steel knuckle. Also is you ever choose to use the stance coil over kit for the z31 it uses the S Rear subframe lower mounting.87T, My build thread http://z31performance.com/forum/z31-…lee-s-87t-rb26 -
[quote]Spooledup300z wrote:oh ok, but as for the stance coils for the z31 you can still use them with the z32 uprights you just have to state that you want z32 lower mounts for the rear instead, I know this because 1sickZ used the stances with the z32 uprights on his z and never really ran into any problems! and I have the exact rearend from his car in my car, but I still will most likely pick up a spare set of z32 uprights and have the mounts rewelded, it would actually be cheaper for me that way cause I know people!Originally posted by badboyz31I actually think I found something the would really help with the angel of the mount as they replace the bushing with spherical ball joints! I'm gonna give them a try and see if they would help angle them better!
It's so much easier to just swap the bearing/hub, rear E-brake assembly into the rear 240 steel knuckle. Also is you ever choose to use the stance coil over kit for the z31 it uses the S Rear subframe lower mounting.1uz Swapped, lowered, flaked out '86 z31
I tried to contact stance about the uprights and never heard back from them, so maybe they do sale them. Make sure whoever you know, is a good aluminum welder, this will require preheating and some deep root welds IMO. It has to take alot of abuse87T, My build thread http://z31performance.com/forum/z31-…lee-s-87t-rb26 -
yea i know a few guys who have been welding for 20+ years and are excellent aluminum welders, as for the the z32 uprights you can buy them from tougefactory just contact them and you can also buy the from frsport.com!1uz Swapped, lowered, flaked out '86 z31
DMANNSenior Member- 544
Not really all that hard to make the z32 uprights to work, and yes…1sickz did have a issue with the bushings starting to tear on him…
Hammer shock tower, cut angle mounts and mount shocks done.88na2T-s13,q45 swap 12.6@110mph
87T 2+2 auto,stock -
from what I can tell the mounts are not torn at all, and this is the exact rear from his car, also I get the hammer shock tower part, but I'm just not getting the angle mounts!DMANN wrote: Not really all that hard to make the z32 uprights to work, and yes…1sickz did have a issue with the bushings starting to tear on him…
Hammer shock tower, cut angle mounts and mount shocks done.1uz Swapped, lowered, flaked out '86 z31
