Ok, I know Jason has done it and so have I ...
But you know what? I just discovered that the sleeves for the inner and outer
journals are a different size.
The inners are; OD = 0.939" (23.87mm), ID = 0.557" (14.17mm)
The outers are; OD = 0.900" (22.87mm), ID = 0.527" (13.66mm)
Lengths are about the same.
The outers (where the mod occurs) don't fit the ploy bushings.
How did those that where successful in completing this mod deal with this problem?
I will probably have my local machine shop make 2 copies of the inner
sleeves but maybe there is another solution.
Yeah, the one tool I don't have is a machinist's lathe.
