Response Type BIG BRAKE kit, 13 inches for non-turbo hubs :)
I'm piecing together some stuff to make a big brake package, my aim is to have it bolt-on for people with non-turbo front hubs (yay!) but of course you'll need longers studs pressed in (ichiba/peak…)
*snip*
So it's becoming reality, there's been a little delay on the rotors but they are coming, the calipers will be arriving sooner, the brackets will be made on demand
The rotors will be 2-piece with T6061 hats (black) designed to fit over Z31 non-turbo front hubs (all years) in 4 AND 5 bolt pattern, the rings will be 330x32mm high tensile iron, slotted, directional vane
Calipers are going to be massive mofos (black), pads will have approximately 24% greater surface area and 8% larger piston area than Z32/R32 calipers
A very very attractive pre-buy for 3 lucky sobs will begin in mid-october, delivery around mid-november, everyone else will be directed to a vendor who will pick up the remaining sales
Pre-buy price will be announced when it starts, retail price will be determined by vendors, but should be well below $1000 for the complete front brake kit
If everything goes right, I will also have extended wheel studs available at an attractive price
They will look something like this:
acemanSenior Member- 1566
Re: Who's interested in 2-piece brakes?
I still cant figure out who needs $1500 in brakes when the stock size stuff is more than adequate. Ask anyone here who road races about stock z brakes. Our lemons car has na brakes with porterfield pads and nobody out brakes us.Nearly all men can stand adversity, but if you want to test a mans character make him a moderator. -
jamesSenior Member- 978
GE with a 2 piece rotor, late style turbo rear brakes could be fitted direct to any Z31 Rear trailing arm without modification.G-E wrote: I'll figure out something for the rears
The only reason i had to space my calipers out was to suit the rotor I was using, had i opted for a custom hat/race style rotor it would have been bolt on.
Didn't Advanman have a bolt on mega front brake upgrade/brackets/ hat style/floating rotors already ?
more options the better I suppose.85 Turbo Slick Top
Just before anyone goes crazy, it would be less than $1000 total, pad selection would be enormous, and replacement rings would be ~$100 each -
DeleriousZSenior Member- 6874
I still can't figure out why you're here. What's the last positive thing you've posted?aceman wrote: I still cant figure out who needs $1500 in brakes when the stock size stuff is more than adequate. Ask anyone here who road races about stock z brakes. Our lemons car has na brakes with porterfield pads and nobody out brakes us.
GE I'll be interested in this in probably early 2nd quarter next year? Need to purchase expensive welder and a few other things first lol.
And yes, AV had a sweet front setup using Wilwood Superlight calipers IIRC.
1990 jetta vr6'd -
NissanEggSenior Member- 5220
With 32mm thickness, that requires R32 GT-R calipers or Brembo calipers and aren't that readily available in the US. That's some money in just the calipers. Unless you can find us a great deal on R32 GT-R calipers I would think about it.
Powered by Fund Solvaren.
Leave that to meNissanEgg wrote: With 32mm thickness, that requires R32 GT-R calipers or Brembo calipers and aren't that readily available in the US. That's some money in just the calipers. Unless you can find us a great deal on R32 GT-R calipers I would think about it.
NissanXRMASenior Member- 3245
[quote]DeleriousZ wrote:I would have guessed you twin piston turbo brakes were limiting your setup. #Ihavebigfrontbrakeslookatme #form>functionOriginally posted by acemanI still cant figure out who needs $1500 in brakes when the stock size stuff is more than adequate. Ask anyone here who road races about stock z brakes. Our lemons car has na brakes with porterfield pads and nobody out brakes us.
And yes, AV had a sweet front setup using Wilwood Superlight calipers IIRC. -
Yeah, I can't brake hard enough when I'm sitting in the driveway.
1990 jetta vr6'd -
Guys don't turn this thread into crap like so often happens… only comment if you are suggesting improvements/specific options you want, or just showing your support
If you DON'T want 2-piece brakes then avoid this thread please, or go race with your stock brakes and have fun! -
badboyz31Senior Member- 2403
Well I'm just getting the Arizona Z car big front brake setup with 6 pot calipers for the z31, also is 2 piece, and since I have z32 rear setup I can get the 4 pot brake kit for the rear, should be perfect for street and road racing. Plus all together the kit is just of $2k for a complete track car brake setup!1uz Swapped, lowered, flaked out '86 z31
$1350 vsbadboyz31 wrote: Well I'm just getting the Arizona Z car big front brake setup with 6 pot calipers for the z31, also is 2 piece, and since I have z32 rear setup I can get the 4 pot brake kit for the rear, should be perfect for street and road racing. Plus all together the kit is just of $2k for a complete track car brake setup! -
[quote]G-E wrote:$1350 vsOriginally posted by badboyz31Well I'm just getting the Arizona Z car big front brake setup with 6 pot calipers for the z31, also is 2 piece, and since I have z32 rear setup I can get the 4 pot brake kit for the rear, should be perfect for street and road racing. Plus all together the kit is just of $2k for a complete track car brake setup!1uz Swapped, lowered, flaked out '86 z31
Hey G-E, do they make 2-piece rotors for the stock sized R32 GT-R rotors and calipers?
I would think about 2-piece rotors for GT-R setup and the GT-R calipers if could be had at decent price. Do you know if the R32 bits bolt right on the turbo hubs and such with just a spacer to center the caliper like we do with Z32 bits?
[quote]DeleriousZ wrote:For someone hanging onto my nuts so hard, you obviously only read posts about daydreaming. 90% of my posts are helping people who were never taught to think for themselves.Originally posted by acemanI still cant figure out who needs $1500 in brakes when the stock size stuff is more than adequate. Ask anyone here who road races about stock z brakes. Our lemons car has na brakes with porterfield pads and nobody out brakes us.
A z31 with big brakes look cool but nobody who buys them will ever use them. That won't stop you or anyone else from wasting money but you don't need to make people new to the z31 think that brakes are a weak point.
My buddy had R32 GTR calipers on z32 rotors and 88 turbo hubs, I don't know how much he had to space the calipers.Nearly all men can stand adversity, but if you want to test a mans character make him a moderator.
