S13 Steering Rack Bushings
  • 1artworkz
    1artworkz
    • 1143
    #31
    We have discussed the issue of rack movement some time ago.
    There was even a video of rack movement with OEM rubber bushings.
    For those that missed it. Here are the installation instructions.
    The steering rack bushings have been made from
    custom molded PMC-790 urethane rubber with these
    specifications; 90 Shore A hardness, 300 pli (pounds per
    linear inch) tear strength and 600% elongation at break.
    At the time of manufacturing a coating of silicon spray
    mold release (friction reduction lubricant) is transferred
    to the product. In addition, the mold surfaces are highly
    polished.
    This molding process produces a very glossy surface
    with a micro bonded silicon surface lubricant. This
    attribute is a plus for reducing unwanted sounds
    sometimes produced by polyurethane parts when part
    of a dynamic suspension system. The steering rack (SR)
    housing assembly is not designed to move once installed.
    The rubber bushings are present to reduce road surface
    vibration felt by the drive through the steering wheel.
    What you need to do before installing them:
    You will need to physically clean and remove any residual
    mold release compound from all contact
    surfaces of the bushings. During this
    cleaning process the SRB mating
    surfaces will become scuffed
    which promotes friction and
    reduce the possibility of
    unwanted movement of the SR housing
    within the hold down clamps
    3 Steps: In your set of SRB you will find an abrasive
    pad. This pad, acetone and clean rags are the cleaning
    tools required.
    • Clean each of the bushing with a clean rag dipped in
    acetone. Rotate the rag to a new area for each of the
    bushing’s mounting surfaces. Once completed, repeat
    the process.
    • Using the supplied abrasive pad wetted with acetone,
    scrub the inside/outside surfaces of the two ‘C’ clam shell
    shaped parts and the same for the ‘split-O’ donut bushing.
    • Lastly, clean the SR housing mounting surface and hold
    down clamps as prescribed above.
    A NOTE about the use of acetone. Read the
    WARNINGS on the acetone container. Use only in an
    open well ventilated area. Acetone is extremely
    flammable with a flash point of -4 °F.
    Visually inspect each of the surfaces to confirm that they
    are de-glossed and lightly abraded.
    Micro abraded mating surface, free of lubricants, oils,
    grease and lose debris form a tighter bond through
    increased surfaces adhesion.
    At this point the bushings can be installed.
    RECOMENDED
    HOWEVER, for additional adhesion:
    To prevent any movement at all; prior to
    assembly, apply a liberal coating of a
    moisture cure polyurethane adhesive to
    all mating surfaces. 3M Windo-Weld and
    Sikaflex 1A are this type of adhesive.
    Remove any residual or excess adhesive with mineral
    spirits. Other aggressive solvents may damage painted
    surfaces or affect the curing of the adhesive.
  • Gregmatic
    Gregmatic
    • 2193
    #32
    I've got a writeup coming soon on how to remedy this situation. Will cost less than $25 and take a little bit of fab time. Really simple elegant solution to this, surprised somebody hadn't done it already.
  • Augustus Maximus
    Augustus Maximus
    • 1739
    #33
    Gregmatic;324699 wrote: I've got a writeup coming soon on how to remedy this situation. Will cost less than $25 and take a little bit of fab time. Really simple elegant solution to this, surprised somebody hadn't done it already.
    When.
    Cha iro
    at least you gave it a whirl.
  • jaqattack02
    jaqattack02
    • 1185
    #34
    Augustus Maximus;331835 wrote: When.
    What he said. I need to do something about mine.
    My 1986 Turbo Build
  • Gregmatic
    Gregmatic
    • 2193
    #35
    soooooooooooooon
  • frostvectron
    frostvectron
    • 1044
    #36
    Play on BDG Game official site India.
    Justin
    1986 NA 2-seater
    Race Videos
    Build Thread
  • DeleriousZ
    DeleriousZ
    • 6874
    #37
    1990 jetta vr6'd
  • Augustus Maximus
    Augustus Maximus
    • 1739
    #38
    Yeah…soon.
    Cha iro
  • G-E
    G-E
    Junior Member
    • 6320
    #39
    He doesn't have the $25 obviously…
  • 1artworkz
    1artworkz
    • 1143
    #40
  • DeleriousZ
    DeleriousZ
    • 6874
    #41
    Gary your image doesn't work for me.
    1990 jetta vr6'd
  • Parker
    Parker
    • 966
    #42
    Zoey - 1987 Z31T GLL - HKS EVC / CM SS 3" turbo-back / Stance GR+
    Black Betty - 2014 Audi C7 S6 APR1
  • DeleriousZ
    DeleriousZ
    • 6874
    #43
    Weird man, still doesn't pop up for me on the forum, but if I copy the url it works. oh well!
    1990 jetta vr6'd
  • jaqattack02
    jaqattack02
    • 1185
    #44
    So what ever happened to this?
    My 1986 Turbo Build
  • Axel kain
    Axel kain
    Moderator
    • 1221
    #45
    I have some S13/14/Z32 busings siting on my shelf, although not 100% fit on the round one, its better than none/busted crap. it's what I have on the M30…
    sigpic
