S13 Steering Rack Bushings
  • Augustus Maximus
    Augustus Maximus
    • 1739
    #46
    S13 bushing is garbage on a Z31. Movement is bad, even with wide bracket.
    Greg did post his fix in buried thread somewhere.
    Cha iro
    at least you gave it a whirl.
  • jaqattack02
    jaqattack02
    • 1185
    #47
    Just wanted to update, there's a guy on Facebook selling a Delrin bushing for the passenger side that gives a solid mounting and eliminates side to side movement of the rack.
    My 1986 Turbo Build
  • reddzx
    reddzx
    Senior Citizen
    • 6440
    #48
    Its David Carroll aka "Mr 510"
    1991 Hard-body 2WD
  • 1artworkz
    1artworkz
    • 1143
    #49
    dave@vg30.com
  • 300zxturboftw
    300zxturboftw
    • 3709
    #50
    Nice, just contacted him. Good update.
  • youngfg
    youngfg
    Member
    • 44
    #51
    Here is how I do it on my race cars.
    Just a small L shaped bracket that welds to the bushing bracket an connects to the rack via the power steering fitting.
    This setup has worked for many 7 plus hour long races.
    • 150121_0001.jpg (87.4 KB)
  • 300zxturboftw
    300zxturboftw
    • 3709
    #52
    Has anyone been in contact with Dave? I don't have facebook…tried emailing at dave@vg30 and info@vg30. Will anyone FB message him for me? lol
  • adamvann3
    adamvann3
    • 4160
    #53
    Talk to 88turbozx. He was prototyping a promising set of solid steering rack bushings.
    I was lucky enough to stumble on a set of Gary's poly rack bushings. Coming from busted OEM, these are amazing!
    86na - BlueZ
    85t - Mr Tickles
  • G-E
    G-E
    Junior Member
    • 6320
    #54
    Those delrin ones might have a problem… I'll wait for conclusive evidence
    budget seeds.
  • 300zxturboftw
    300zxturboftw
    • 3709
    #55
    Ah, thanks for the responses. I'm in no hurry until track season this summer. Definitely have some play in my rack though.
  • 1artworkz
    1artworkz
    • 1143
    #56
    This spring's redesigned rack bushings (SRB) will have the driver's side be the hardness of Delrin.
  • jaqattack02
    jaqattack02
    • 1185
    #57
    Care to post more details? I haven't had any issues with mine so far.
    Also, this is the first I've heard of it. There haven't been any complaints in his Sale thread on Facebook.
    My 1986 Turbo Build
  • Axel kain
    Axel kain
    Moderator
    • 1221
    #58
    Without relevant information to support this claim, your pointless post, was pointless.
    sigpic
  • Mr.510
    Mr.510
    Member
    • 44
    #59
    So here's an update on my Passenger's Side Solid Steering Rack Mounts: I've got one customer whose rack is apparently moving in the Delrin mount. He's running 265/35/18 Toyo Proxy R1R front tires and is running a power rack with no pump. These mounts are in about 20 other Z31s at this point and my original S12 version is in about 50 cars without a single issue. The rack in my S12 hasn't moved at all in 3+ years of hard use on sticky tires. For reference, the Z31 rack is 1mm smaller diameter than an S12 rack but the mounts are made from the same material with the same amount of 'crush' when the bolts are fully tight.
    Also at issue is the fact that there were apparently two widths of Z31 rack mounting straps even though Nissan says they were all the same. My solid mounts are made for the wider brackets that apparently came on the earlier cars. (I don't know when they changed.) The guy with the slipping rack says he has the wide mounting strap that fits properly in the bushing. From reading above that the poly mounts have to be glued to the rack to keep it from slipping perhaps we'll just need to do the same with solid plastic mounts if they slip.
    I do intend to produce driver's side Delrin rack mounts at some point but people with S12s have been running these on the passenger's side only for nearly 10 years (someone else produced them long ago, but stole a bunch of people's money and vanished) and there are no complaints on the S12 forum. Actually everybody that has one, mine or the original guy's, raves about it.
    So that's where things are at. I have the mounts in stock if anybody wants to buy one. They're $30 plus $7 shipping in the USA. I ship worldwide at additional expense.
    I am behind on answering both PMs and emails right now, sorry! The best way to reach me is to email david@vg30.com
    http://www.vg30.com
  • Axel kain
    Axel kain
    Moderator
    • 1221
    #60
    Really I see the drivers side being the more likely to hold the strongest in any situation. As well as, it makes more sense for both to be the same material to compliment each other!
    sigpic
