link1463 link1464 link1465 link1466 link1467 link1468 link1469 link1470 link1471 link1472 link1473 link1474 link1475 link1476 link1477 link1478 link1479 link1480 link1481 link1482 link1483 link1484 link1485 link1486 link1487 link1488 link1489 link1490 link1491 link1492 link1493 link1494 link1495 link1496 link1497 link1498 link1499 link1500 link1501 link1502 link1503 link1504 link1505 link1506 link1507 link1508 link1509 link1510 link1511 link1512 link1513 link1514 link1515 link1516 link1517 link1518 link1519 link1520 link1521 link1522 link1523 link1524 link1525 link1526 link1527 link1528 link1529 link1530 link1531 link1532 link1533 link1534 link1535 link1536 link1537 link1538 link1539 link1540 link1541 link1542 link1543 link1544 link1545 link1546 link1547 link1548 link1549 link1550 link1551 link1552 link1553 link1554 link1555 link1556 link1557 link1558 link1559 link1560 link1561 link1562 link1563 link1564 link1565 link1566 link1567 link1568 link1569 link1570 link1571 link1572 link1573 link1574 link1575 link1576 link1577 link1578 link1579 link1580 link1581 link1582 link1583 link1584 link1585 link1586 link1587 link1588 link1589 link1590 link1591 link1592 link1593 link1594 link1595
Real reason for 87-89T hubs?
  • G-E
    G-E
    Junior Member
    • 6320
    #16
    1. A bolt-on hub has a plain 66mm bore, the slip-on hub has a stepped bore 66mm and 68mm.... the rotor I.D. is 68.1mm, the wheel I.D. is 66.1mm
    2. The bolt on rotor has a shorter hat as it mounts to the backside, but is also thinner, so the inner surface of the rotor is almost the same as the slip-on turbo rotor
    3. If using a bolt-on hub lathed to allow slip-on rotors, there will be a 1mm gap around the bore between the hub and rotor, you can lathe the hub bore a bit and machine a spacer ring, much like many wheels are sold with a large 73.1mm bore and a spacer ring to reduce it for the application, which in most mid-80's and up nissans is 66.1mm
    4. Lathing a bolt-on hub should not cost more than obtaining a slip-on hub, but your results may vary… a "fair" price for lathing the hubs is $40 each, use your judgement
    5. There are currently 2 big brake kits designed for use with bolt-on hubs lathed down to ~150mm to accept the rotor as a slip on, using longer studs as well -- htey are designed to use the 66mm bore
    6. Using a bolt-on hub with a slip-on rotor ultimately removes the 66mm bore from use by any corresponding wheel, bolting on a hub-centric spacer with a 66mm lip may sound like it fixes the problem for the wheel, but consider that there's nothing centering the spacer except the lugs anyway, so you can skip the hub-centricity and use the lugs to center your wheel directly
    7. R32 GT-R rotors and calipers work perfectly on slip-on hubs, all you need is 4mm of washers between the caliper and mounting ears, and of course z32 conversion lines
  • michaelp
    michaelp
    • 9384
    #17
    G-E;341436 wrote: 7. R32 GT-R rotors and calipers work perfectly on slip-on hubs, all you need is 4mm of washers between the caliper and mounting ears, and of course z32 conversion lines
    Same process as Z32 brakes…likely because R32 and Z32 suspension and brake setups are nearly identical.
  • RocklinMike300zx
    RocklinMike300zx
    • 276
    #18
    Alright, well it seems I may be well served to find some late model turbo hubs, and as luck would have it there actually is an 88 z31 in a nearby pick n pull, though it is probably not a turbo…anyways, I'll be heading up there probably Monday and while I'm at it I think I will grab some J30 hubs, as I believe they are the same, no? At least, I think I read that in the brakes thread, and even if they aren't I can sell them to an s13 owner for use.
  • reddzx
    reddzx
    Senior Citizen
    • 6440
    #19
    J30 are not the same
    1991 Hard-body 2WD
  • RocklinMike300zx
    RocklinMike300zx
    • 276
    #20
    Ah, that's a shame. Guess I'll snag them to sell to the 240 crowd but I'll have to either do some machining or hope the 88Z is a turbo at the yard to save some money on my hubs. I actually like the idea of fabricating my own stuff but I am also a lazy slob sometimes.
  • G-E
    G-E
    Junior Member
    • 6320
    #21
    For some stupid reason, nissan like other manufacturers switched to sealed bearing hubs in the 90's… so we share a spindle design with s12, r31, and the elusive m30, anything newer is nothing like
