link1862 link1863 link1864 link1865 link1866 link1867 link1868 link1869 link1870 link1871 link1872 link1873 link1874 link1875 link1876 link1877 link1878 link1879 link1880 link1881 link1882 link1883 link1884 link1885 link1886 link1887 link1888 link1889 link1890 link1891 link1892 link1893 link1894 link1895 link1896 link1897 link1898 link1899 link1900 link1901 link1902 link1903 link1904 link1905 link1906 link1907 link1908 link1909 link1910 link1911 link1912 link1913 link1914 link1915 link1916 link1917 link1918 link1919 link1920 link1921 link1922 link1923 link1924 link1925 link1926 link1927 link1928 link1929 link1930 link1931 link1932 link1933 link1934 link1935 link1936 link1937 link1938 link1939 link1940 link1941 link1942 link1943 link1944 link1945 link1946 link1947 link1948 link1949 link1950 link1951 link1952 link1953 link1954 link1955 link1956 link1957 link1958 link1959 link1960 link1961 link1962 link1963 link1964 link1965 link1966 link1967 link1968 link1969 link1970 link1971 link1972 link1973 link1974 link1975 link1976 link1977 link1978 link1979 link1980 link1981 link1982 link1983 link1984 link1985 link1986 link1987 link1988 link1989 link1990 link1991 link1992 link1993 link1994
Rim Size Recommendations 87 300ZX Turbo
  • baseball
    baseball
    Member
    • 65
    #16
    My thinking is that I'll go with the 22'5's for now - there conservative in width. At least, I'll be able to gauge how much wider I can go with the next set.
    I
  • frostvectron
    frostvectron
    • 1044
    #17
    225 will be stretched on 9's but it'll work.
    Justin
    1986 NA 2-seater
    Race Videos
    Build Thread
  • baseball
    baseball
    Member
    • 65
    #18
    Hey Justin, I purchased the rims, but not the tires. Based on my rims specs for 87 turbo, how wide do you think I can go on tires, before I start getting into clearance issues? Enkei 396-890-6518SBC RP03 Wheel 18x9.0 +18 5x114.3 SBC.
    By the way:
    the only other options if I want to keep the speedometer accurate with the Dunlop Direzza ZII
    is:
    255 35 18
    if I go with a different brand than:
    245 35 18 would work to.
  • baseball
    baseball
    Member
    • 65
    #19
    thanks Justin, I'll be going with the 255's. doesn't really make sense to go with a tire narrower than the rim, when I can benefit from improved traction - provided they fit correctly.
