Subframe Bushing Dimensions
NissanXRMASenior Member- 3245
Would anyone be so kind to either list the dimensions of aluminum subframe bushings, or have a solidworks file/drawing? I'm planning on making a set when I have access to a lathe again.
Thank you. -
The total height can be anywhere from 68-71mm, the inner diameter is 21mm, the upper end is chamfered, and the body of the bushing will have to be 75.2mm…
You figure out the rest
FilipeSenior Member- 524
If you're trying to make SOLID subframe bushings, measuring something squishy won't help will it? -
You couldn't describe it in a better way? Or list all the dimensions (larger outer diameter of the annulus, length of the extruded larger OD, ect.) instead of saying "figure out the rest". There are only 5 dimensions. -
No fighting or I'll come over and start bitch slappingCha iro
at least you gave it a whirl.
