Options for brake master cylinder
midianSenior Member- 421
Let me add:
for RHD cars - BM50 from 21 pathy SE works excellent, btw, it has same PN as UK non-abs zenki turbos.
46010-06p02, 3 port. -
GregmaticSenior Member- 2193
^ I have the same setup as this with the same results. Extremely rigid pedal with short travel. Pad compound can help but only so much…Originally posted by NissanEgg View PostI run the 17/16" on Z32 4-pot fronts and stock Turbo rears. Pedal is overly stiff, like as in 997 911TT stiff. Scares people at first, but I am used to it.
I would try to rebleed the brakes again to make sure you get all the air out. I had to bleed my brakes about 3 times to get all the air out of the calipers and BMC.
HarvesterUTMember- 74
So the swap went well: 1" BMC with Z32 calipers and rotors all around. The pedal feel is a little more firm, but not abrupt. I am happy so far.1988 300ZX Turbo Shiro Special
