Z32/S13/S14 - multi-link rear suspension swap
Cool, good to know, thats what i'm looking for, and the stock Z32 spring rate is about right?
Good thing is they make Illumina's for it..
badboyz31 wrote:
with stock z32 shocks and springs in the rear, the ride height is about stock of what the stock z31 suspension is.Kevin
OK now I have a question, at one of my favourite wreckers they have a nice condition Q45 with the 4.1L, I didn't check the date but that makes it the newer one, does anyone know if that one would be a good rear end to get for such a swap?
I remember track width being significantly wider on Q's than s13.... but which one and how much? -
if you're going to steal that Q45 diff at cookstown, im going to murder you. :-(G-E wrote: OK now I have a question, at one of my favourite wreckers they have a nice condition Q45 with the 4.1L, I didn't check the date but that makes it the newer one, does anyone know if that one would be a good rear end to get for such a swap?
The y33 rear end is not the strong one. You want the earlier version (G50?) pre 1997 rear end. The rear suspension is utterly close to the s14.
Rick88ssSenior Member- 2433
[quote]Careless wrote:Originally posted by G-EOK now I have a question, at one of my favourite wreckers they have a nice condition Q45 with the 4.1L, I didn't check the date but that makes it the newer one, does anyone know if that one would be a good rear end to get for such a swap?
Early bird gets the worm. The race is on!Shiro #443
I have one of these sitting on the floor of my shop right now..
They are wider then a Z32 rear end, so will not work too well unless you like that look..
I have the center section out of a S14 that I'm going to use in conjugation with the Q45 arms, diff, uprights and Z32 struts.
The nice thing about the early Q45 rear diffs is they have a VSLD and use the same size axles as the turbo Z32.
As far as i can tell the arms are basically interchangeable between the Z32 and Q45.
BDG.Kevin
I have a nismo short-nose LSD sitting on a shelf with 5-bolt axle stubs, so in such case the non-vlsd later Q45 diff would work as a shell to swap into or I guess it wouldn't matter which year then…?
How about track width on them, is the early Q narrower/wider than the later Q, has anyone measured ? -
I haven't compared between the early and late Q45's, all i know is the 94 and earlier is wider then the Z32 sub frame by a couple of inches hub to hub.. I did measure it at one time but did not record the number. I'll try to remember to get the actual measurements from my 94 Q sub frame tonight..
According to the FSM's track widths are as follows:
94 Q45 - 61.8"
02 Q45 - 61.4"
Z32 NA - 60.4"
Z32 TT - 61.2"
Z31's - 58.1" on Xenon's Z31 page under general specs.
89 S13 - 57.5"
But track width is not really going to help us here unless you know the tire width, wheel width and wheel offset. You cant really calculate the distance from outside tire to outside tire without all this.
For what it's worth: http://ateupwithmotor.com/automotive…finitions.html
I know the later Q's (after 2002) had an open diff and the traction (limited slip) was controlled by the anti lock brakes applying the brakes to the side that was slipping, but on the plus side had a RP ratio of something like 3.13 for those looking for better economy or top speed. The 94 I'm using as my parts car uses the same 3.54 rear end as our early turbo cars, so it's easy to get the speedo pinion to get everything calibrated and have VSLD.
The difference in durability comes form the fact that some came with 2 spider gears (later models) and some came with 4 (earier models). All had an output axle size that is actually the same as the turbo Z32, so heavier then ours..
G-E wrote: I have a nismo short-nose LSD sitting on a shelf with 5-bolt axle stubs, so in such case the non-vlsd later Q45 diff would work as a shell to swap into or I guess it wouldn't matter which year then…?
How about track width on them, is the early Q narrower/wider than the later Q, has anyone measured ?Kevin
but that's for an R230 diff then, right?K_Scheeringa wrote: but on the plus side had a RP ratio of something like 3.13 for those looking for better economy or top speed. The 94 I'm using as my parts car uses the same 3.54 rear end as our early turbo cars, so it's easy to get the speedo pinion to get everything calibrated and have VSLD.
shit… 3.13… my car would be a highway monster. -
yes for the R200 diff..
Here is the dims from a 94 Q45.
Its hard to make out.
Hub to hub 64 3/4"
Small side 28 1/2"
Large Side 46 7/8"
From small side to axle 6 3/4"
Large side to axle 17"Kevin
millsapsSenior Member- 133
so reading through this the s13 or s14 are the best options. i should be buying a z31 here soon and will have stance coilovers from my s13. would the s13 subframe be best because i can get my hands on one for damn near free?
also where can i find just an s13 how to thats well detailed and organized? -
badboyz31Senior Member- 2403
what's with all this taking and less swapping, I have been driving on my setup for a little over 2k miles now, get to work guys!!
dampening set at 10 clicks to the stiff side and 12k springs all around is fun for DD driving, why? because race car!!1uz Swapped, lowered, flaked out '86 z31
ButterSenior Member- 1519
S13 is quite adequate.millsaps wrote: so reading through this the s13 or s14 are the best options. i should be buying a z31 here soon and will have stance coilovers from my s13. would the s13 subframe be best because i can get my hands on one for damn near free?
See page 14/15 of this thread, more info throughout this thread and the one you're on now.
viewtopic.php?f=2&t=27070sigpic -
OK silly mix'n'match question time…
I have nismo clsd with beefy 6-bolt axle stubs, not the 3x2 style like 240sx, I believe it's out of a GT-R…
Would I swap that into a 240sx housing, or the Q45 housing?
And if I swap that into S13 subframe, will I need the Q45/TT axles? What if I use Q45 spindles/hubs which axles then?
