Z32/S13/S14 - multi-link rear suspension swap
  • badboyz31
    badboyz31
    • 2403
    For the guys with the s13, q45, and z32TT hybrid rear ends, I just need to know how long you guy's driveshafts are?
    I will soon be swapping the whole rear end set up from Mike D's old car into my Z, and the only thing I need to know is what you guys did about your driveshafts? lengthen? u-joints and pinion flanges?
    1uz Swapped, lowered, flaked out '86 z31
    Custom vg30et tube chassis drift exocet project
  • Careless
    Careless
    • 13279
    Butter wrote:
    Shaft Length
    2-seater: 760mm (measured between C/L of U-joints)
    2+2: This should be the above + the difference in the stockers?
    Thank you for this.
    I'm assuming C/L stands for "Center Line", I.e - center of U-joint bores on the ends of the DS?
  • ShamWow
    ShamWow
    • 1905
    See the tape position?
    Also note, 760+-Hangover tolerancing.
    bdg game login.
    "produce first.talk second."
  • Careless
    Careless
    • 13279
    as a note for anyone making a custom driveshaft.
    Dave @ ShaftMasters wanted measurements from the face of the trans seal to the pinion flange, as the yokes and companion flanges he used were much larger than stock… so those measurements would only work on stock driveshafts, right?
    Or....?
  • Butter
    Butter
    • 1519
    He will most likely use the components I listed. They are pretty much the only aftermarket driveline parts I was able to find for Nissan applications. The 1310 U-joint and all these parts that go with it are much larger than stock.
    Compared to stock Z31 and S14…
    sigpic
  • Careless
    Careless
    • 13279
    exxxxxxxcrement. looks good.
  • 1SickZ
    1SickZ
    • 634
    http://www.driveshaftspecialist.com/
    awesome driveshaft/price. I'm sure he can pull up the info for my driveshaft i had it built for a 88trans and a Q45flange for the diff. awesome customer service.
    Praying....
  • DMANN
    DMANN
    • 544
    Since I have this DS.
    I'll totally agree to this statement excellent quality all together.
    88na2T-s13,q45 swap 12.6@110mph
    87T 2+2 auto,stock
  • RedDemon
    RedDemon
    • 362
    Hey guys, so I've been looking around for an s13 rear end and I found a guy who's selling a full sub-frame minus the shocks for $250. It came out of a 92 s13 which has the vlsd so my question is would it be better to buy the sub-frame off of an open diff equipped s13? Everyone here talks about wanting an open rear end of an s13 and the only think I can make out why is because the KAAZ LSD is cheaper for an open diff 240sx than it is for a VLSD.
    1988 SS #71
    Better to remain silent and be thought a fool, than to speak and remove all doubt.
  • DMANN
    DMANN
    • 544
    There is no difference in the 2 subframes.
    If you don't want the VLSD, sell it and buy a open diff if you want.
    Ahh, your from Canada, good luck trying to find one without a VLSD
    87T 2+2 auto,stock
  • ZFast88Z
    ZFast88Z
    • 1882
    DMANN wrote: There is no difference in the 2 subframes.
    Yes there is.
    The bullshit stops, when the GREEN light drops.
  • DMANN
    DMANN
    • 544
    Yes there is.
    Care to explain!
    87T 2+2 auto,stock
  • ZFast88Z
    ZFast88Z
    • 1882
    Link geometry was improved slightly for the S14. At a minimum the toe link is at a different angle.
  • RedDemon
    RedDemon
    • 362
    ZFast88Z wrote: Link geometry was improved slightly for the S14. At a minimum the toe link is at a different angle.
    I never mentioned anything about the s14. Only about the s13's
    I'll probably do that, thanks. The guy who's selling it is not too far from you (near Sarnia)
    1988 SS #71
  • ShamWow
    ShamWow
    • 1905
    I realize a ton of people out there are using Q45 and Z32 rear brake parts on there S13/S14 rear subframes…Its extremely common. Z32 calipers/ebrake hardware is kind of expensive, and then who knows how your going to get the ebrake cables hooked up.
    What I have just realized is that the Z31 caliper/rotor bolts on with a few washers, and you can most likely re-use your factory ebrake cable.
    http://tinyurl.com/3kzo8t4
