Z32/S13/S14 - multi-link rear suspension swap
  • 1SickZ
    1SickZ
    • 634
    #61
    Ford Falcon wrote: . Do you think it's possible to heat up and adjust the mounting points on those so the struts will line up properly? I would imagine it would be expensive to do. Also, are you all using Z32 rear struts with this mod, or has anyone found any others that with work with the mounting point on this knuckle?
    I'm not heating and moving it that's for sure!
    Pretty sure everyone is using s13 coilovers
    and if utilizing the z32 uprights then you would just need z32 lower mounts
    on the s13 coilovers
    The easiest would be s13 uprights and s13 coilover/shocks.
    Praying....
  • DMANN
    DMANN
    • 544
    #62
    Ahh you just missed a ebay member that sold the knuckles for $20.50.
    I believe ken az used a angle metal piece up top to adjust for the angle, but, he was using the z32 subframe.
    I have not had a chance to put the z32 knuckles on the Z yet( too much snow to move the car to the shop) and I'm waiting for the z32 rear brakes to come in to finish it up!
    88na2T-s13,q45 swap 12.6@110mph
    87T 2+2 auto,stock
  • Ford Falcon
    Ford Falcon
    Junior Member
    • 25
    #63
    Coilovers are a li'l expensive for me right now. I'll just go with a pair of basic Tokico rear S13 struts and shocks mounted to Z32 knuckles. It'll be another month before I get underway. Hope to add some of my own pics.
    Right now I'm just cleaning out the underbody. Stripping away all the sound deadening rubber and grime, back to the metal, then I'll get all the welding done and prep it right.
    My Project '88 Z31 To Do List:
    S13 rear subframe,
    '91 Q45 R200 diff,
    '91 Infiniti VH45DE,
    Z33 6-speed transmission
    Custom wire harness
  • Black 89Turbo
    Black 89Turbo
    • 495
    #64
    I just read this whole thread. Im wondering what the point is to change the subframe? Just for suspension reasons?
    89' Turbo-R.I.P. (scrapped)
    07 Frontier XE <----(turd) daily
  • OK85ZX
    OK85ZX
    • 1690
    #65
    Geometry, among some other smaller pros.
  • DeleriousZ
    DeleriousZ
    • 6874
    #66
    Being able to not have -6* of camber when you get to proper ride height, if you're into that sorta thing.
    1990 jetta vr6'd
  • Butter
    Butter
    • 1519
    #67
    For the basic reason that the front suspension on our cars is reasonably good, yet the rear is a antiquated, cheap design.
    -Multi-link distributes less un-dampened shocks to the chassis. Results in a more comfy ride, especially when upgraded.
    -Many aftermarket upgrades fit it and are plentiful.
    -Subframe has an extra mounting point.
    -Much better alignment. Car no longer looks like dog taking a dump.
    -I've never weighed them, but I would guess Z31 is heavier.
    sigpic
  • Black 89Turbo
    Black 89Turbo
    • 495
    #68
    I figured it was because theres always so much camber and the fact that theres a wide selection of suspension for the 240's
  • 1SickZ
    1SickZ
    • 634
    #69
    I did it mainly for the driveline. everything else made it an easier decision.
    bdggame-india.in.
    Praying....
  • joeyz31na
    joeyz31na
    • 189
    #70
    So let me get this straight, after getting the actual s13 subframe welded up you will need, a new drive shaft, figure something out for the exhausts and e brake, and s13 springs and shocks if i didint go right to the stance/serial 9 set up? Anything im missing? I have 4 lug currently so i would imagine i could keep the s13 hubs
  • DMANN
    DMANN
    • 544
    #71
    joeyz31na wrote: So let me get this straight, after getting the actual s13 subframe welded up you will need, a new drive shaft, figure something out for the exhausts and e brake, and s13 springs and shocks if i didint go right to the stance/serial 9 set up? Anything im missing? I have 4 lug currently so i would imagine i could keep the s13 hubs
    S13 has coilovers, your choice to use either 4/5 lug, and there is nothing you have to weld on the s13 frame you have to box in the places you have to cut out to make the s13 frame clear on the Zed, and yes driveshaft because of the short nose diff!
    87T 2+2 auto,stock
  • Butter
    Butter
    • 1519
    #72
    You may need a half moon style aftermarket RUCA to clear your suspension. Depending on what you use and how you mount everything, it may rub. You'll probly want to adjust camber anyway when you slam it.
    sigpic
  • KevinA
    KevinA
    • 128
    #73
    I thought the front mounts on the S13 didn't quite go far enough forward, so you had to make new front mounts on the subframe?
    Kevin A
    1986 RB20 300xz 2+2
  • DMANN
    DMANN
    • 544
    #74
    Correct, many ways to do it.
    Use one of the methods described in this thread or use the imagination!
    87T 2+2 auto,stock
  • Ford Falcon
    Ford Falcon
    Junior Member
    • 25
    #75
    Well, it's been 6 months since we saw any activity on this thread. So this weekend I'm going to get a couple of quotes to get the parts fabricated and the welding work started on my swap. I've got an S13 rear sub-frame, the fuel tank is out, and I'm making sure the areas to be worked on are free of any dirt, and such. I'll be sure to get some photos up here when its done. Finally moving forward on this thing.
    S13 rear subframe,
    '91 Q45 R200 diff,
    Custom wire harness
