Z32/S13/S14 - multi-link rear suspension swap
  • DMANN
    DMANN
    • 544
    No. Not in a Z31.
    88na2T-s13,q45 swap 12.6@110mph
    87T 2+2 auto,stock
  • bleakdragonmage
    bleakdragonmage
    • 2093
    RXGhost wrote: well after doing a lot of digging
    i can get a complete rear end less diff for the
    S-13 $ 200
    S-14 $ 700
    is the S-14 worth the extra cost for the slightly better geometry?
    Wow… things are expensive there… the last rear end i was going to buy was 80-100$ complete including the diff…
    1988 570zx SS Edition
    Originally posted by Neil86t
    Just get a slick paint job like mine and its all good. I had a girl that said she wanted to lick my car. She ended up licking my sack…end of story. Bitch ain't gonna lick my car.
  • ShamWow
    ShamWow
    • 1905
    You should be able to get these out of your local pick-n-pull junkyard for $200 or less, complete with diff and everything.
    S14 is not worth the added cost in my opinion. Not in a Z31 anyways.
    "produce first.talk second."
  • Careless
    Careless
    • 13279
    Mike_GruiZinga wrote: S14 is not worth the added cost in my opinion…
    not worth the added cost in initial price that he's been quoted - or are there more costs included in the grand scheme of things?
  • OK85ZX
    OK85ZX
    • 1690
    not worth any added cost
  • Careless
    Careless
    • 13279
    Still kinda doesn't answer the question.
    I have an S14 sub frame laying around in my backyard, which is why I am curious to know of any additional cost beyond acquiring the unit itself.
  • z31t
    z31t
    • 624
    The s-14 has more width hub to hub. The mounting holes in the rear are slightly different but only slightly. People either stretch the factory bushings to make them fit or there are aftermarkets with the holes slightly offcenter.
    lm7 swapped z
    350z 6speed
    s475 turbo
    microsquirt ems
    street car
    http://www.youtube.com/user/redz31t?blend=21&ob=5
  • Butter
    Butter
    • 1519
    Given the choice for the same price, get the S14.
    sigpic
  • OK85ZX
    OK85ZX
    • 1690
    All that info is also earlier in this thread (not specific changes, just talk about geometry etc)
    bdg game.
  • ZFast88Z
    ZFast88Z
    • 1882
    Careless wrote: Still kinda doesn't answer the question.
    Careless,
    In discussions with 1SickZ when we were both doing this swap, I had less notching of the body to do then 1SickZ did. Whether this is because I used an S14 subframe vs his S13 subframe, or because I installed SPL arms instead of the arms he used, I'm not entirely sure.
    The bullshit stops, when the GREEN light drops.
  • Careless
    Careless
    • 13279
    Careless,
    Thank you sir.
    Considering my subframe has absolutely everything except for the diff itself (cables, shafts, rotors, brakes, etc…) I should just buy a diff and adjustable links. I have a JDM S14 subframe with the electronic hicas… not sure how it differs, but I think adjustment ability is better if you use an eliminator bar with adjustable rod hicas replacement links… or so I've been told.
    Maybe something to do in a year or two. My car can use a lot more work in other areas before I even go that far.
    If my rear shocks and springs take a crap, I'll start on this early…
  • RXGhost
    RXGhost
    • 510
    Yeah I have been looking for almost 5 months and the S-14 there is nothing local
    the S-13 I can pull out of pick and pull and its $200 for everything
    the S-14 I am having to get shipped and some of them wanted almost $1000 for the complete
    1984 300ZX - 1988 VG30T Engine, Trans, Diff, ECU
    1998 Mazda B-2500, And a lot of bikes
  • Careless
    Careless
    • 13279
    RXGhost wrote: Yeah I have been looking for almost 5 months and the S-14 there is nothing local
    check anywhere that has front clips from japan land. they usually get cars shipped with the rear end. you could probably get an s15 rear end with vlsd and everything included for 1000… :-/
  • Butter
    Butter
    • 1519
    NOTICE:SUBFRAME SWAP DRIVESHAFT INFO!
    Here are the parts I've used on driveshafts for the subframe swap. These are part#'s for Powertrain Industries https://www.powertrainindustries.com/catalogs.htm . It should be enough info to steer your local ds shop in the right direction so they can build you a shaft. Here it go.
    Slip Yokes
    30A: Part#3103-30
    71C: Part#3103-24
    T-5: Part#3103-26
    U-joint
    1310 Spicer non-greaseable
    Pinion Flange
    S14: Part#3102-21
    Pretty sure all S-chassis are the same. Compare the measurements of this part and measurements on your diff pinion flange to make sure if it will fit.
    PART NUMBER 3102-21
    PILOT DIA. 1.967
    BOLT CIRCLE DIA. 3.200
    BOLT HOLE DIA. .395
    FACE TO C/L 1.772
    Shaft Length
    2-seater: 760mm (measured between C/L of U-joints)
    2+2: This should be the above + the difference in the stockers?
    sigpic
  • Butter
    Butter
    • 1519
    I have a slip yoke for a T-5 if anyone needs one. PM me.
    sigpic
