4th Time my Z has caught fire (injectors again)
 EyspireSenior Member EyspireSenior Member- 268
 4th Time my Z has caught fire (injectors again)*EDIT* I still love my Z despite this ongoing crap
 In Australia we didn't get the recall and i'm sick of going about my daily driving-life to have it catch fire again and again and scare the living daylights out of me. This time the second I fired the engine it started, it looked like it was near/around the first and second injectors (opposites to eachother). Very little damage other than a burnt connector and lead, but i can see a very suspicious crack in the hose join on the other side of the fuel rail.
 I've heard that you do not have to run the car to find the leak just pressureize the fuel line to find it. How do I do this? Auto-priming it won't do it will it?
 sprtcrazy17Senior Member sprtcrazy17Senior Member- 1685
 OK So here's the damage. Two injector connectors (actually 1 and 3) were burnt out, and one injector lead was scorched. Nothing major like i was afraid of. So i didn't find any evident fuel leaks at all, I disconnected the two injector connectors that were burnt out and ran the car on 4 cyl for a while with no trouble, there was nothing to suggest it was caused by a fuel leak, i'm thinking it was electrical because it caught fire the MOMENT i started my Z the other day, it was instantaneous in other words.
 As a diagnostic, I temporarilly crimped two new connectors on and held them in place with electrical tape. Started the car, runs fine, no issues at all on idle or increasing the rpm. I ran it for about ten minutes and couldn't smell any fuel or see any evident faults, using a torch. I don't know if I should risk driving just yet?
 One last issue - When I was doing a diagnostic I bumped this sensor (see below image) and the metal tab that should be join to the sensor came off with it's lead. So i have no way of joining it back together. What the hell is this sensor used for?!
 Engine Coolant Temp, on your gauge.- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra -
 bronzemfpSenior Member bronzemfpSenior Member- 412
 if it caught fire before, it will do it again. To me it sounds like a perfect time to upgrade injectors, or at the very least, buy some post-recall injectors from someone in the states here. I have a set of post recall NA injectors, but if your car is a turbo model, that wont do you much good :-/
 Buy 6 new injectors and be done. No more worries.
 Rick88ssSenior Member Rick88ssSenior Member- 2433
 buy new injectors or get Nistune and upgrade them. Replace all of the fuel lines with fuel inj. hose. Use the Nissan hose clamps. Also get new connectors and solder and heat shrink them on.
 You can pressurize the fuel system by disconnecting the blue plug under the rear carpet by the fuel pump, and put battery power on the plug going to the fuel pump.Shiro #443
 Shady195Senior Member Shady195Senior Member- 679
 Damn dude, if I saw this sooner I woulda sent you new injectors for free (you pay shipping lol)… Had my recall done and then did an NA2T I tried to get rid of them for quite some time, ended up throwing them out along with a ton of other Z shit I had that enver went anywhere1989 300ZX 2+2 N/A GLL
 Auto to Manual Swap
 NA2T Complete
 BLOZ UPSenior Member BLOZ UPSenior Member- 2971
 I would have replaced my injectors after the first time… what are you waiting for?BLOZ UP.com
 NissanXRMASenior Member NissanXRMASenior Member- 3245
 The 5th time…BLOZ UP wrote: I would have replaced my injectors after the first time… what are you waiting for?
 [quote]NissanXRMA wrote:Originally posted by BLOZ UPI would have replaced my injectors after the first time… what are you waiting for?
 The 5th time…BLOZ UP.com
 akronzSenior Member akronzSenior Member- 308
 thats the way all hondas should end up. and what body kit is that on his z. i LOVE that front bumper
 http://www.neospeed.freeforums.org
 1985 300zx n/aRegretfully Retired
 1997 240sx srdetSadfully Sold
 (!Attention!) If you have an 85 - 89 thats not stripped out a shell rolling body preferred contact me at330 328 2789 (ask for rick)
 Chrisw_2003Senior Member Chrisw_2003Senior Member- 2503
 wait..... You have been using the same injectors and hoping for a different outcome?
 http://www.darwinawards.com/
 maybe god is trying to make sure you dont have kids :|
 just change the damn things and re wire it, if you can do all the repairs you have done on your car, putting in new wiring and injector plumbing should be cake
 clostoyoSenior Member clostoyoSenior Member- 312
 Bro, your car is too nice to hope it doesn't catch on fire. Specially when a set of used Turbo injectors go for $50 tops used. Stop messing around and change them.
 Am I the only one that thinks leaky injectors are not your only problem?
 A cracked insulator on one of your plug wires is probably what's causing the fuel to be ignited.
