Tranny or Clutch
mistah mofroSenior Member
- 705
Tranny or Clutch
First thing that happened Was after a small mountain run, there was a slight grinding sound. You can hear it right in front of the of the bellhousing, so next day I dropped the tranny retightened the pressure plate and made sure nothing was wrong but everything seemed fine, but theres two stripped bolts on the pressure plate. Second thing that happen made about another "Run" after that there was a very loud whine in 2nd and 3rd, then the next day I couldnt shift into gear like as if the Clutch went. Characteristcs like cant put into gear in while moving or sitting still with the clutch pedal all the way down, so i grab all the essentials clutch/pressure plate/release bearing/pilot.
Now the problem is when I went to go move it for street cleaning it shifting fine, but there was some added vibration at random RPMS. Its a 73 240z with a 280zx tranny also it would throw 5th out of gear, i mean like it would never hold 5th gear this was happening before I had the car though.
So now Im baffled, any ideas anyone? -
NicelowZ86NA2TSenior Member
- 657
Re: Tranny or Clutch Assembly?"
You need to drill out the flywheel and put the two broken bolts back in. That will cause your clutch not to be all the way against the flywheel and that can cause problems. Can't see it being a tranny issue.98 Maxima SE 5-speed. Daily
07.5 Silverado Duramax. 650whp. Weekend Sled Puller. It just never ends.
86/88 Turbo Project.
90TT. GT675RS turbos, 3" exhaust, 740cc Nismo injectors, Wiseco Forged Pistons, and much more!! 574whp on 25psi on 93. Gone! -
- 705
NicelowZ86NA2T wrote: You need to drill out the flywheel and put the two broken bolts back in. That will cause your clutch not to be all the way against the flywheel and that can cause problems. Can't see it being a tranny issue.
P.s- Your avatar is awesome.
Edit Also was wondering if anyone would know where the source fo the whining would come from, someone told me throw out bearing a while ago. -
- 657
Yes, the throw out bearing can cause whining. Pull it apart and see what it looks like in there. If you got the full clutch kit, replace it all. Rear main, pilot bushing, tob, flywheel, clutch, pressure plate, new front seal in the tranny, etc.......98 Maxima SE 5-speed. Daily
- 705
Thanks a lot man,cleared up a lot for me. I got the pressure plate/release bearing/pilot/clutch/and flywheel I will be doing today or tomorow. -
nismopuAdministrator
- 2221
Fifth gear popout is common and can be caused by bad bushings on the tranny mount or excessive play inside the tranny itself. If thats the case its rebuild time and rebuild kits cost about 60-80 bucks. They take about a weekend to do if you have a gear puller set and a vise."Its the s12's sexy over weight step daughter, the z31" -
- 705
So i did the whole everything other than the pilot bushing (dam near new), it took about 4 hours on the side of the road but it worked out. Also my pedal was put of adjustment so that helped out aswell. Its really hard to put it in gear but I lost quite a bit of tranny fluid when we put it back. Im going to do tranny flush tomorow and go from there. -
CarelessSenior Member
- 13279
maybe one of the detent balls on your trans is fucked up somehow. if it's hard going in gear and it pops out of 5th, it may be worth a look (consult FSM). -
Dave@SBCSenior Member
- 494
Some of Nissans older pilot bushings didn't have the silicone/oil inpregnation correct and could cause a whine. I agree that the tranny popping out of gear sounds like it's tranny related. Please tell me you fixed the stripped out bolt holes. That would couse release issues and vibration.Dave
Z31P sponsor
800-988-4345 ext: 114
http://www.DXDRacingclutches.com
90 Z32 Base 5spd, 05 Z33 Touring 6spd.
SOLD- 84 Z31 NA2T GLL 5spd
- 705
Hard Shifting
Dave@SBC wrote: Some of Nissans older pilot bushings didn't have the silicone/oil inpregnation correct and could cause a whine. I agree that the tranny popping out of gear sounds like it's tranny related. Please tell me you fixed the stripped out bolt holes. That would couse release issues and vibration. -
- 2221
Its cheap to rebuild those tranny's and doesn't take very long to do. If when you accel and decel while holding the shifter in 5th, you will feel excessive movement inside then its probably time for a rebuild."Its the s12's sexy over weight step daughter, the z31" -
- 494
Sounds hydraulic. If you still have the damper in the system, you must bleed it from the bleeder on that as well. You'll never get all the air out if you don't. Some tests; pull the boot back on your slave cyl. and see if there's fluid coming out. If so, it's bad. You can rebuild your master cyl. or buy a new one. If you're still running the stock clutch hose there are stainless ones out there that replace the damper as well. My vendor Zspeedperformance offers one. MSA as well? Another test, remove slave cyl and remove the boot around the clutch fork to the bell housing. Re-install slave cyl and measure the travel of the release bearing. It needs to move at least .400. Have you adjusted the clutch pedal?
If all of that checks out, then may be the clutch. I often have local guys bring in their cheap autoparts store clutches for us to test. They don't always work.Dave
Z31P sponsor
- 705
We bled it until the clutch master was clean and bled it from the slave, it was like a slight grey and now its clear. Also made sure when we were opening and closing the bleeder that it didnt bubble out so no air would go back in the line.
Also when the car is off I can shift through the gears semi-smooth (wasnt ever bread and butter to shift) but all that smoothness disappear the moment I turn the car on. On another note I'm not losing any fluid from the clutch master so I wouldn't think the slave can be faulty. I was thinking that something isn't allowing any pressure to build up. -
- 494
mistah mofro wrote: Also when the car is off I can shift through the gears semi-smooth
When adjusting the pedal, spin the threaded rod nearly out of the clevis. Where you can just see it poking through the other side. Does that improve it? if it's a stock clutch in good condition, that should be all the travel you need.
How was it installing the clutch? if you had to draw the tranny in with the bellhousing bolts, you may have bent the disk. OR.. the disk may have gotten bent before you installed it. I don't know the care your friend took with the kit, but it's another possibility.
Did you grease the input shaft? Too much grease can create drag between the disk splines and the shaft. Too much grease can also attract dirt (clutch dust), causing the same issue later down the road. There should be no more then a thin coating.
Last resort, remove the kit from the car. Bolt the kit with the disk inside togther with the flywheel and actuate the fingers of the clutch in a press. You should be able to spin the disk freely at .400 of bearing travel.
If you get frusterated, send everything to me and I'll take a look at it. If you can eliminate the clutch assembly from the equasion, then you can start to narrow down the issue.Dave
Z31P sponsor
- 494
nismopu wrote: Its cheap to rebuild those tranny's and doesn't take very long to do. If when you accel and decel while holding the shifter in 5th, you will feel excessive movement inside then its probably time for a rebuild.
tranny could be junk. Would explain notchy shifting and gear popping out. I used to have an RX7 that I kept going through tranny's. I got a junkyard tranny for cheap and it was notchy. Used lucas 80/90 gear oil and made evrything butter.Dave
Z31P sponsor
