Tranny or Clutch
mistah mofroSenior Member- 705
I was just saying that to ensure that the Trans actually shifts on it own. I did a trans on a Miata and You couldnt even get into gear with the car off. I'll take a look at the pedal and I might (sigh) drop the tranny again, just might buy an entirely new clutch even. But I'll go to all my resorts before I drop it again.lol, when the car is off, there is nothing spinning. Therefor it doesn't matter if the clutch/ hydraulic system even works. I could completely remove the clutch disk from the car and it'll do the same thing.
Thanks SBC big help here. -
Dave@SBCSenior Member- 494
NP man, it's how I roll.Dave
Z31P sponsor
800-988-4345 ext: 114
http://www.DXDRacingclutches.com
90 Z32 Base 5spd, 05 Z33 Touring 6spd.
SOLD- 84 Z31 NA2T GLL 5spd
Noticed somethings here and there and thought I would list them:
-Near impossible to downshift from neutral (rev match or occasional luck)
-When I clutch in and out at freeway speeds (50-70mph) vibration in the rear
-Doesn't always feel like its all the way in gear
-1st is ridicoulousy Hard (like im talking about chris brown and rihanna punch hard) to put in gear any circumstance
I was going to mess with the linkage today but due to some things happened earlier, like a melted fuse panel reasons because of a shitty bay area shop (before i had the z) and drained alternator or battery this may put the trans on hold and I may just deal with it for a bit. But i may have a resource for another tranny, thing is he's the same guy welding my suspension on the 240z so I may knock all of it out in one swoop.
Any other ideas? -
sounds like your trans is pretty well on its way out.Dave
Z31P sponsor
thinking the same, looks like Ill try to stick it out until i grab another tranny sometime.Dave@SBC wrote: sounds like your trans is pretty well on its way out. -
[quote]mistah mofro wrote:thinking the same, looks like Ill try to stick it out until i grab another tranny sometime.[/quote:2c9rj64m]Originally posted by Dave@SBC:2c9rj64msounds like your trans is pretty well on its way out.
Well turns out the the tranny isn't done in completely, i adjusted the clutch pedal alittle more and finally shifted WAY better. Previous was definately done though under some more inspectio the clutch had very slight cracks. Im going to drive it for sometime and maybe bring it back to the mountains and see if i get the same problem.
