Changed out the clutch master cylinder, changed out the slave cylinder, took out the clutch damper and replaced that with a 280ZX Brake hose, bled the system, and am using a BRAND NEW DXD Stage One Rally Series Street clutch.
Now the problem...
The pedal is extremely soft, and continues to be SUPER soft all the way until its down almost to the floor, it gets hard when its 30% close to the floor, and continues to be hard until it is depressed fully.
The Clutch Rod Adjustment underneath is screwed in as far as it can go, and turning it the other way makes the pedal even softer...
We are CLUELESS on whats going on.
Firhawks goign to change the clutch line and re-install the clutch damper tomorrow to see if changes anything...
Other than that were completely clueless, this is the ONLY thing keeping my Z to be driven.
Now the problem...
