Weird Starting Problem (84 Turbo)
datsunkingJunior Member- 13
Issue:
The car runs and idles fine, but I went into the gym (an hour) and came back out to drive to work and it just wouldn't start, it acted like it was getting no fuel, just would turn, sorta catch, sputter, and die. Later that day I came back after work, sputtered a little, kept cranking, and it fired up. Ran rough for a bit, but drove it home 15 miles with no issues whatsoever, no sputtering, it ran strong. The previous owner had warned me of this issue and said it's very sporadic, and it is.
New parts: fuel pump, injectors, fuel filter, 93 octane gas, and ECU.
Has anyone dealt with this before? I'm at a loss, when the car starts she'll run forever and really well. It's starting that has a problem. It's only happened once so far but I had to walk to work and need this fixed, as it will be my daily driver.
Thanks,
DK -
Hot start issue. Nissan Technical Service Bulletin #TS84-106
http://www.askatech.com/AskATechLive…rack/NN006.pdf
I doubt you can get the kit anymore or if you do have it, it may be on the fritz.
My 84T has the kit and still has the occasional hot start issue.
Read this thread too, it may be of some help:
http://www.zcar.com/forum/11-84-89-t…hot-start.html
vgpowerJunior Member- 25
I found the kit, for the dirt cheap price of $175 lol is it even worth it, and what do I do to prevent myself from waiting at a gas station for an hour if this does occur? Are their any tricks? I have to road trip this thing back home 600 miles lol -
Which part number did you order? I've seen people recommend the opposite of what the manual says.Originally posted by Z_Karma View PostHot start issue. Nissan Technical Service Bulletin #TS84-106
I have an 84 manual turbo, which the manual says 22626 01P01.
84 turbo with an automatic transmission is 22626 02P01. I don't want to blow $150 on the wrong part if it matters. -
flatfootSenior Member- 253
I had similar issues on mine.
It went away when I installed a set of Efans and programmed the controller to run them for a full minute after the engine is shut off.Life's short
Go fast
Have a blast
Leave a good looking corpse -
Can I just bypass this garbage, the part comes up available on some websites, I order it and they email back going 'oops we don't have it' lol -
irace911Senior Member- 172
Distributor (CAS) maybe. $100 on rockautp or so. Did you check your wires, ignition coil, can you hear the fuel pump go in the back.
I don't think its fuel related BC it runs. But it just might be. I'd checkthe dizzy,wires,coil, prw2.Compressed Springs is the scariest shit EVER!
" border="0" alt=""> -
I recommend always buying new dizzys. Yields Z31Performance, and a lot of other stuff. From experience.Compressed Springs is the scariest shit EVER!
