Yeah, so after I go out of my way to make sure the turbo Z has A/C with the pathfinder intake modification, the compressor blows a seal in the back. fan-freaking-tastic. So, now that I know $40 worth of freon has vented itself to the atmosphere, I have decided to fix it up right. I pulled the evaporator out from under the dash (which was really easy) and its gonna get a good cleaning. Then replace the compressor, o-rings, dryer, expansion valve, foam seals, blah, blah, blah. After I'm done, this system will work like it should have.
Note: this core should be silver in color, not black and clogged with leaves, bugs, and other sh*t.
