ok i may get flamed for this, but hey... im trying to join your side....
ive posted this on club-s12 as well, i just want to get as much info as possible to help with the swap.
if i get a hold of a non-turbo motor, what will i need when i get some boost, if i decide to?
i understand the motor bolts right in, as its availible on the s12 se, but what else may i need to make it run and work properly...
i plan on ditching the a/c, as well as any smog equipment, ill retain the cat though, for good measure...lol
any ideas?
thank you
any ideas?
thank you
