Upgrade to PRW-2 Ign. Control Module (Power Transistor Unit)
Black 89TurboSenior Member
- 495
Go to your nearest junk yard and have a field day.89' Turbo-R.I.P. (scrapped)
862sikSenior Member
- 2159
tatsu;314795 wrote: mine is a PRW-2A from a questMy Build Thread -
TomakzeSenior Member
- 624
I just got one out of a Quest as well. The factory bracket that comes with it makes the install stupid easy, and look factory. I installed it in exactly the same place as the original one! The PRW-2a works great."Understeer is when you hit the wall with the front of the car. Oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall. Torque is how far you take the wall with you…"
-'68 Datsun 1600 Roadster
-'85 300zx Turbo
TearingRavenSenior Member
- 2572
Tomakze;322549 wrote: I just got one out of a Quest as well. The factory bracket that comes with it makes the install stupid easy, and look factory. I installed it in exactly the same place as the original one! The PRW-2a works great.
- 624
TearingRaven;323189 wrote: Post pics!
This was zero effort. It bolts right up (You do have to bend a little tab out of the way, but psh, that is too easy to count). Yours looks really nice though…"Understeer is when you hit the wall with the front of the car. Oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall. Torque is how far you take the wall with you…"
-'85 300zx Turbo
millsapsSenior Member
- 133
got mine today hopefully going to put it in tomorrow. btw pathfinders are the easiest ones to get. its on the pass side of the intake manifold near the back. maxima's were not too easy i gave up and found a pathy.
Powered by Fund Solvaren. -
michaelpSenior Member
- 9384
Altimas are the easiest to get, they're right on the MAF. lol- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
- 133
michaelp;324499 wrote: Altimas are the easiest to get, they're right on the MAF. lol -
jaqattack02Senior Member
- 1185
Maximas are easy, right by the coil. 12mm deep socket to take out one bolt. Snip the harness and it's out. Even comes with a bracket.Prius… because Pretentious wouldn't fit across the back of the car…
My 1986 Turbo Build -
CarelessSenior Member
- 13279
inqui-Z-torSenior Member
- 9020
Careless;324554 wrote: we need more cool threads that make use of other nissan thangs so easily.'84Z31 GLL turbo|theZenthusiast site: http://www.thezenthusiast.com |
- 13279
inqui-Z-tor;324562 wrote: Agreed .. but then .. ?? -
- 2572
Well apparently we are able to utilize the newer CAS as well?
- 9384
TearingRaven;324577 wrote: Well apparently we are able to utilize the newer CAS as well?- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
- 2572
Any proven benefits?
