Upgrade to PRW-2 Ign. Control Module (Power Transistor Unit)
  • G-E
    G-E
    Junior Member
    • 6320
    Why not make it bent over above the bottom one or even the other way, like a Z, instead of twisting? The unit would sit flat then and fabrication would be simpler
  • jaqattack02
    jaqattack02
    • 1185
    The one's in the Maxima and Pathfinder both come with their own bracket that are pretty easy to find a place to attach to.
    My 1986 Turbo Build
  • Tomakze
    Tomakze
    • 624
    The best brackets are from the Nissan Quest and certain Maximas. Those are the ones I've shipped to various people. All I had to do was bend a tab to mount it in the stock location, and it looks great. I'm out of PRW-2s with those brackets, but still have two spares. One with the bulky pathfinder bracket, the other without any bracket. I'll do a JY run soon to get more.
    "Understeer is when you hit the wall with the front of the car. Oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall. Torque is how far you take the wall with you…"
    -'68 Datsun 1600 Roadster
    -'85 300zx Turbo
    Build Thread:
    http://z31performance.com/showthread…)build-thread!
  • aZinMA
    aZinMA
    • 146
    ^^ "The best brackets are from the Nissan Quest and certain Maximas."
    So I've heard/read. There aren't any around here though, and the zip ties I was using was driving me insane. So I had some extra stainless left over from a pinball machine project (Funhouse), was bored and voila. I don't expect to sell any, I really only threw that number up there cuz if I didn't I'd get people wanting to know how much to make them one.
  • Tomakze
    Tomakze
    • 624
    aZinMA;344904 wrote: ^^ "The best brackets are from the Nissan Quest and certain Maximas."
    I think your bracket looks great! In theory, it is a MUCH better solution than the Maxima/Quest bracket. I was more mentioning how easy it usually is to get one of those brackets. I understand if it is hard to acquire though… I can only get a limited supply depending on what shows up in my local JY. It would be good to have a reliable source when scavenging dries up. I'm out right now, for that matter.
    -'85 300zx Turbo
    Build Thread:
  • Big_E-Dog2
    Big_E-Dog2
    Member
    • 30
    infiniti m30. has the mount for the pwr 2 (but theres a pwr1 in its spot) and it has a cover..
    Cant beat it LOL!
  • Tomakze
    Tomakze
    • 624
    Big_E-Dog2;344999 wrote: infiniti m30. has the mount for the pwr 2 (but theres a pwr1 in its spot) and it has a cover..
    Cant beat it LOL!
    With a cover? Very cool! Besides, from what I understand, the PRW-1 is still an upgrade.
    -'85 300zx Turbo
    Build Thread:
  • michaelp
    michaelp
    • 9384
    M30s are rare as fuck, though.
  • Big_E-Dog2
    Big_E-Dog2
    Member
    • 30
    well then guess theres a way to make some money lol!
    pics of said backet…
    Powered by Fund Solvaren.
  • amreboot
    amreboot
    Banned
    • 9875
    Here is my setup.
    Its a complete assembly setup from a M30 including the black plastic cover.
    The transistor is the PWR-2
  • Rustspecs13
    Rustspecs13
    • 283
    You can also get those off S13's.
    ~Alex
    splatter fake blood on fubar'd quarter and roll out.
  • Urstin
    Urstin
    • 1168
    Just wanted to add, anyone with an 84-85 who has done the PRW-2 mod and/or idle block off, BUY AN 87NA ECU! Holy dogfish is it an improvement!
    " I spend another hour trying to rip the bolt out of the subframe, pausing every five minutes to scream and contemplate how I get myself into these situations. Two cars over, a guy urinates. I watch the steam waft off of the fresh puddle in the gravel. It merges with the blowing snow and is cut by the aerodynamic wedge of a nearby Fiero. Beautiful. Another pry and the carrier finally falls to earth. I walk out of there $80 lighter, which makes me more mad." - Brian Kolar
  • alyason
    alyason
    Junior Member
    • 16
    4/87T was having some serious cold start issues. The ECU gave code 21 (if I remember correctly) which is the ignition system. Turns out this can be the PTU, CAS, or Coil, according to the FSM, or a bad ECU. I happen to have spares of everything but the PTU and ECU so I swapped as much as I could with no difference.
    Symptoms:
    Terrible cold start, would sometimes die without increasing throttle.
    High idle, up to 1200 at times.
    Would dive the RPMs from 900-400 and back up
    Would miss every ~4 seconds
    letting off the throttle, shifting to neutral, or coming to a stop would sometimes kill the engine or dive the RPMS like above.
    When up to temperature, it ran ok but conservative gas mileage would be at 9 max in town, highway still up to 26
    I upgraded to the PRW2 and it fixed everything. Writing this just in case someone else has similar symptoms.
  • Filipe
    Filipe
    • 524
    ^^^Impressive. Just got mine today!
  • designate72
    designate72
    • 330
    Urstin;n761399 wrote: Just wanted to add, anyone with an 84-85 who has done the PRW-2 mod and/or idle block off, BUY AN 87NA ECU! Holy dogfish is it an improvement!
    Does this also apply to the 86?
    1986 300ZX N/A 5Speed project. Needs work, but that's the point, isn't it?
