Refresh
This website z31performance.com/forum/z31-performance-upgrade-forums/cosmetic-interior-exterior/1506-perfect-wheel-offset-and-size-opinions-desired is currently offline. Cloudflare's Always Online™ shows a snapshot of this web page from the Internet Archive's Wayback Machine. To check for the live version, click Refresh.
Perfect wheel offset and size? Opinions desired...
  • Perfect wheel offset and size? Opinions desired...
    Would anyone care to state what they think is the perfect aftermarket rim size and offset to flush the rims with the body?
    I had some +46 offset rims 16x8 that although they created the battleship stance, my camber problem dissappeared while I tried them out since they tucked in pretty far. It would be cool to have 17x10's on back and have them flush with the body, and 17x8's up front.
    Thanks
    15 X 7 with 0mm backset results in flush with my fenders front and rear. That is on an 84.
    You should be able to calcualte how much offset you need as you get wider tires.
    I'm thinking that with 10" rims you should need about +38mm to be flush?
      Not 100% sure but I think a 20 or 25mm offset puts it pretty close to flush with the fenders. Then again it most likely varies for body style and for front and back. I dont know too much about this subject so I dont even know why i'm posting.. Oh thats right CAUSE ITS 0* OUTSIDE! :evil:
        on a 87-89 turbo: 18x9 +19 front, 18x10 +32 rear
        That would sit damn flush, not 100% sure the rears would fit on the stock lugs though.
        2008 BMW E92 335i 6MT
          after HOURS of research I have found that one could use 17x9 with a +15 in the front and 17x10 with a +25 in the rear for clearance and flush fender mounting purposes...this is what I will be running very soon...255/40/17 front, 285/40/17 rear...I know it is possible to run a 265 width up front but if my calculations are correct you'd need somewhere between a +17 and +20 on a 17x9 wheel. I have probably spent somewhere near 15 hours pouring over pages and pages and PAGES of 17" wheels and tires...as well as reviewing wheelshow and making lots of theoretical section width calculations to come to my desired selection.
          2006 Scion tC (Wife Whip)
            Taris Blue wrote: I know it is possible to run a 265 width up front but if my calculations are correct you'd need somewhere between a +17 and +20 on a 17x9 wheel.
            That'll be wicked close...too close to chance imo. I tried 275's on 18x9 +24 and they rubbed on the strut tube badly. I switched to 245's and they are extrememly close, but they don't touch. A 17" wheel may make the difference in your calcs on the positive side but I would stick with 245's on the front in any application even with a +17 offset.
              I can't believe .. no one's posted this here ..
              http://wheelshow.redz31.com/
              '84Z31 GLL turbo|theZenthusiast site: http://www.thezenthusiast.com |
              Originally posted by maronee
              PS - by the way your Z31's famous here in japan, dude!!
                like signal mentioned, im also running +24mm 18x9 with 245 meats and they come milimeters from the strut housing
                to run 265's you would need a crazy low offset (about +0 to +10) that would proably stick the tires out of the wheel well and look pretty ghetto
                how do you justify so much tread up front?
                  inqui-Z-tor wrote: I can't believe .. no one's posted this here ..
                  Taris Blue wrote: spent somewhere near 15 hours pouring over pages and pages and PAGES of 17" wheels and tires...as well as reviewing wheelshow
                  Elitist Prick Black Z owner.
                  1986 300zx Turbo
                    Taris Blue:03644 wrote: spent somewhere near 15 hours pouring over pages and pages and PAGES of 17" wheels and tires...as well as reviewing wheelshow
                    [/quote:03644]
                    Oh.. I read that too .. but no one posted the link! And it's hosted right here!
                      18x9 +24 w/ 265/35s fit perfect on the front of my 87.
                      imagination is a virtue
                        I could tell you, but then a little peice of dust landing on top of your fender might cause it to bend in .00045mm and cause tire rubbing issues with the sizes I would recommend.
                        sigpic
                          lol. never seen a Z31 with good wheel fitment besides yours^^
                          that may change soon enough.
                          I wrap my paper weights in glitter.
                          • #14
                            I run 255s up front on my 17" track wheels. Can't remember the offset right now but I use a 1" adapter with the wheels. They are from a Z32TT. I may look for direct fit wheels down the road that are 17x9s & 17x10.5s as I would like to get more rubber under the car for the track.
                            378whp 445wtq
                            • #15
                              Butter wrote: I could tell you, but then a little peice of dust landing on top of your fender might cause it to bend in .00045mm and cause tire rubbing issues with the sizes I would recommend.
                              lol, i like Butters style.
                              I'd like to know. also, how about 84 fenders with 87-89 'widetrack' susp. taking into account additional steering angle?
                              i tested 17x9 +20 out back on stock susp. and if fit pretty tight on the cntr arm and pretty flush with fender. but haven't figured out the front yet.
                              ps. your not alone
