Keep it Zenki!
 floridaZSenior Member floridaZSenior Member- 2781
 So am I the only one who thinks that the hood scoop on the turbos makes or breaks the zenkis?Feedback- viewtopic.php?f=18&t=19840
 slammedcoupeSenior Member slammedcoupeSenior Member- 721
 Big Slappy ZSenior Member Big Slappy ZSenior Member- 237
 So does it look terrible on an AE too? A chuki is basically the same thing.slammedcoupe;341880 wrote: looks good on zenkis, would look horrible on a chukiPrius… because Pretentious wouldn't fit across the back of the car…
 My 1986 Turbo Build
 TomakzeSenior Member TomakzeSenior Member- 624
 Yeah, I'm lost on why a scoop would look bad on an '86. The car is more similar to a Zenki than a Kouki. The average joe can't even tell the difference at first glance.
 Actually, if I end up doing a kouki front end swap, I plan to integrate a scoop somehow. Either a Zenki scoop, a generic one, or I make one. I"Understeer is when you hit the wall with the front of the car. Oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall. Torque is how far you take the wall with you…"
 -'68 Datsun 1600 Roadster
 -'85 300zx Turbo
 Build Thread: http://z31performance.com/showthread…)build-thread!
 Kimbro SliceSenior Member Kimbro SliceSenior Member- 1561
 I like the scoop on my AE. Just something about it looks good in my eyes.
 2001 Mazda Miata LS
 also a 1989 Nissan 240SX
 50th AE Build Thread SOLD 2015
 ae it works in my opinion as the rear arches are "bolt on"
 the 86 has widened rear arches with sheet metal does it not?
 personally I don't like the pre/86 cars
 id rather have a 240/260z or an s30
 They are, but the rear of the 86 is shaped exactly the same as the AE. There just isn't a seam there for the attached flares. Front fenders are exactly the same.slammedcoupe;342060 wrote: ae it works in my opinion as the rear arches are "bolt on"
 id rather have a 240/260z or an s30Prius… because Pretentious wouldn't fit across the back of the car…
 My 1986 Turbo Build
 The 200zr-II scoop on the kouki looks good because it matches the body style, as the 84 turbo scoop on zenki/chuki matches the angularity
 while they may be the "same" to you, they are definatly not the same to me.jaqattack02;342067 wrote: They are, but the rear of the 86 is shaped exactly the same as the AE. There just isn't a seam there for the attached flares. Front fenders are exactly the same.
 if the AE flares were molded that may be a different story, but they totally change the look of the car from the formed metal widebody of the 86.
 anyways that's just my opinion, im quite partial to the clean/sleek look that the 86 has compared to the previous years.
 it doesn't really matter much anyways, im planning a kouki front swap to tie into my build
 VenSenior Member VenSenior Member- 510
 86+ flares are the best of all. AE fender flares just look like aftermarket tacked on pieces.
 And +1 on what GE said.
 adamvann3Senior Member adamvann3Senior Member- 4160
 DeleriousZSenior Member DeleriousZSenior Member- 6874
 Someone at Speedhunters must have a z31 fetish lol
 1990 jetta vr6'd
