Z32 TT tranny Swap..
brewster240Senior Member- 150
mace350Senior Member- 396
Thank you, The tranny is installed in my car with shifter and driveshaft…It just did not look like the starter gear would hit the flywheel without shaving the area it mounts to on the tranny.
In about a week I'll know… -
FlawleZSenior Member- 1971
Just to reiterate, the Z32 transmission is extremely strong. People make 900HP+ on them. The only true known weakness is the factory synchronizers in 90-96 models. They simply hate high rev shifts. They were later upgraded in '97 to a much more robust set.545 RWHP & 540 RWTQOriginally posted by Andrew84zx
tacozzzMember- 52
here is another shifter bracket i found for u guys doing this swap…looks like it moves the shifter alil bit further forward then the mazworx.
http://www.xcessivemanufacturing.com/me … 111&step=4We choose to do things not because they are easy but because they are hard. -
NissanEggSenior Member- 5220
Nice find. Now the question is which (the Mazworx or Xcessive manufacturing) bracket works for the Z31? It does seem that the XM bracket moves the shifter further foward compared to the Mazworx.
Timbo. do you have a 2+2 or do you have a 2 seater? When you say you extended the driveshaft, can you clarify which driveshaft you started with? -
nismopuAdministrator- 2221
Xcessive makes some nice parts! A guy I know is like there tester for all the KA parts he makes and its high quality stuff!"Its the s12's sexy over weight step daughter, the z31" -
ZED XMember- 56
He has a 2+2 i would have imagined that he would have started with a standard Series 3 manual driveshaft from a 2+2.Careless wrote: Timbo. do you have a 2+2 or do you have a 2 seater? When you say you extended the driveshaft, can you clarify which driveshaft you started with?
We dont really get 2 Seaters here in Australia
1993 BNR32 GTR - White
Apexi Front/Rear Carbon Strut Brace | Apexi Power Intake Kit | R33 GTR VSPEC Brembos | OHLIN Coilovers | 3.5" Invidia Exhaust (Catback) | HKS Front Pipes | Greddy Profec B Spec II | 17x9.5 Enkei RP-01 W/17x45x245 | Larger FMIC | HKS Adj Cam Gears | Nistune - 253Awkw(339Awhp)@12.5PSI -
Geoffs89PathyMember- 80
ill be doing this soon. z32 5 speed. pathfinder bell housing. pathfinder clutch and clutch assembly.
just need to know what i have to do for a crossmember. and a drive shaft. i already have everything else except the pedals and the clutch cylinders.
i bet if someone did enough research they could find a stock nissan shaft from something. ie pathfinder hardbody ect that is a bolt in shaft for the swap… that would be awesome.
does anyone know how much the shaft gets lengthen or shortened? and which shaft are they starting with? a z31 autobox shaft? or something else? also i imagine its different depending on if you have the 2+2 or the 2+0 like i do. food for thought....
last question. what exactly needs modified for the z32 shifter to work? why wont the stock z32 shifter assembly work in the z31? not in the right place? to far forward or backward? 2+2 or 2+0 ?
thanks.
trying to get this done with as little money spent as possible.
bdg login. -
ZSpeedPerformanceMember- 30
I have not had time to read through all these post but the way you mounted the shifter to the body will quickly take out the u-joint on the transmissions shifter linkage. The stress from the trans moving against the shifter mounted directly to the body kills them pretty fast. You have to have a SOLID trans mount so it can't move against the body if you are going to do it that way. Just a heads up
I have a solid shifter mount sort of like mazworks but is much beefier and adjustable so you can get the shifter in the correct position.
I also have a shift boot plate for the Z32 that may well be adapted into the Z31 also.
Timbo_021Senior Member- 514
I modified the standard bracket to be solid and sit in the right position.. Took a while but its works good. Just need a good shifter that doesnt rattle now
Straya, +61 -
I have thoseTimbo_021 wrote: I modified the standard bracket to be solid and sit in the right position.. Took a while but its works good. Just need a good shifter that doesnt rattle now
i need to do this really soon. > also i need the clutch pedal assembly, master and slave cylinder, clutch line, and drive shaft, or at least know the drive shaft length for the 2+0 (89)
last things will be some kind of tranny mount i will have to fabb, or prefabbed. along with a resurfacing on my old flywheel and a new clutch.
am i missing anything besides about 10 hours of labor?
cause i need to save up, and have this project planned ahead and ready to do in a weekend or so.
price guestimates would help to.
i already have the tranny and a 30a bell housing already.
thanks for the help -
All the 30a tranny mounts will work but your 2wd and 4wd crossmembers are different as are the 4cylinders. Also, finding an early 2wd v6 truck speed drive would be beneficial to you as they run similar rear gear ratios. You can see in the pics I posted above of the black30a and the speedo drive I am refering to. That's all I can think of right now."Its the s12's sexy over weight step daughter, the z31" -
um i dont think you got what i meant by me having a Z32 tranny. i have the z32 5 speed, because i had to buy it just for the bell housing on my VH45 swap on my pathfinder.nismopu wrote: All the 30a tranny mounts will work but your 2wd and 4wd crossmembers are different as are the 4cylinders. Also, finding an early 2wd v6 truck speed drive would be beneficial to you as they run similar rear gear ratios. You can see in the pics I posted above of the black30a and the speedo drive I am refering to. That's all I can think of right now.
i put that bell housing on my pathfinder tranny, and i now have my z32 tranny and my old pathfinder bellhousing to put on the z32 tranny to make it a simple bolt on to the engine and chasis as far as i know. …still not positive that the z32 tranny bracket is the same as the z31 or if it will bolt up.
like i said, i have the tranny already, with the correct bell housing, i just need to figure out what else i need to get, and what else needs to be done.
