Z32 TT tranny Swap..
  • RedDemon
    RedDemon
    • 362
    Careless wrote: sooooo you're going to provide DS measurements with the s13/14 subframe and allllll dat? :-D
    Yup, I gots all that, the drivetrain is now completely done as of today!
    I'm going to put the info in my build thread, but I won't be updating that until I get it running, which shouldn't be too far from now!
    1988 SS #71
    Better to remain silent and be thought a fool, than to speak and remove all doubt.
  • nismopu
    nismopu
    Administrator
    • 2221
    has anyone ever at any point in this thread explained why the maxima flywheel is needed for this swap?
    Also, looking to clean up this thread with info on the maxima fly, clutch, and starter setup. As well as the bellhousing swap method(known as the right way).
    I will probably do it build list style on the first page and have people confirm the accuracy of each component in each list. Sound good?
  • Augustus Maximus
    Augustus Maximus
    • 1739
    Sounds good.
    Using the Z32NA bellhousing, the Maxima flywheel puts the ring gear in almost the correct location (1mm difference I believe)
    Z32
    Maxima
    and finally the Z31 flywheel.
    M30, Z32 and Maxima starter bolts up.The friction surface is 4mm closer to the engine which makes me wonder.
    Cha iro
    at least you gave it a whirl.
  • Cesar H
    Cesar H
    Member
    • 42
    Just to let everyone know the z31 clutch does not fit the Maxima flywheel. So either you get the flywheel redrilled, Maxima clutch, or swap bellhousing which go for 350.00 brand new from Nissan. Which ever route you decide to go with will be the same price wise if you do not already have a 30a so it comes down to whatever works best for you.
  • gardner86zx
    gardner86zx
    • 381
    30a bellhouseing is easy to find and cheap in a junk yard
    86na2t + holset
    feedback
    viewtopic.php?f=18&t=6114&hilit=andrew+gardner
  • datsunzcar84
    datsunzcar84
    • 740
    Got my TT trans just need the Pathy bell.. time for a trip to the pick and pull!
    From what iv'e read/heard the 2WD and 4WD bells ARE the same… some one correct me if i'm wrong..
    D@MN IT FEELS GOOD TO BE A GANGSTA
  • gardner86zx
    gardner86zx
    • 381
    You are correct
    86na2t + holset
    feedback
  • Augustus Maximus
    Augustus Maximus
    • 1739
    gardner86zx;317950 wrote: 30a bellhouseing is easy to find and cheap in a junk yard
    Oh really?
    Cha iro
  • gardner86zx
    gardner86zx
    • 381
    Augustus Maximus;317988 wrote: Oh really?
    Yup. Any vg3xe with standard trany d21,wd21, r50. Xtera. Frontiers
    Lots of options
    86na2t + holset
    feedback
  • Cesar H
    Cesar H
    Member
    • 42
    In my case the closest pick and pull is 6hrs away so cost wise it would be the same, so it all depends on what parts you can source out. If you get the bellhousing everything will bolt up if you dont you can use the Maxima Flywheel with Maxima or SR20 clutch with that said the Z31 does not share the same bolt pattern on the pressure plate
  • Augustus Maximus
    Augustus Maximus
    • 1739
    Kinda makes you wonder how much those assholes on the M30 site was lying. Cuz I ran into the same issue. Post up when you get it going and if you don't I will. This shit is yet to be properly documented in my opinion.
    Cha iro
  • datsunzcar84
    datsunzcar84
    • 740
    Looks like my TT trans swap just entered the next level!
  • TearingRaven
    TearingRaven
    • 2572
    Definitely a swap I want to do in the future.
    Originally posted by Tempestas
    Well, one of the t-tops wasn't latched real well… God only knows where that t-top flew off to at 150+ mph. Didn't scratch the car or anything, just a boom and it was gone. I sure as hell didn't stop to see where it went. I didn't see any stories on the news… so that's a plus.
  • datsunzcar84
    datsunzcar84
    • 740
    TearingRaven;318780 wrote: Definitely a swap I want to do in the future.
    Do ITTTTT!
  • TearingRaven
    TearingRaven
    • 2572
    Well I have a lead on one of these through a friend so it looks like it may become a reality sooner than I thought. That said, my existing 30A would have to take a serious dump unless I come across one of them in a junkyard to source a bellhousing.
    But that said, I REALLY want the Z32 starter
