transmission bushings
  • C.Gesler
    C.Gesler
    Member
    • 79
    Hello all
    does anyone know if the poly transmission harmonic bar bushings are available
  • reddzx
    reddzx
    Senior Citizen
    • 6440
    Not anymore
    1991 Hard-body 2WD
  • C.Gesler
    C.Gesler
    Member
    • 79
    What about the aluminum x-member
    or do I have to go oem
  • reddzx
    reddzx
    Senior Citizen
    • 6440
    Yes, you can buy poly crossmember bushings. Gary Molitor used to make the trans bushings but stop a while back.
    1991 Hard-body 2WD
  • les_joey_paul
    les_joey_paul
    • 743
    #5
    I think hardwood made some. Can maybe convince him to make a batch of bushings. I know there is interest.
    My build thread (:
  • harwood909
    harwood909
    • 131
    #6
    I really should get on this now. haha I will try to get something going on monday. Material is what I need to look into. I've made them for my car and I can make them for you guys too.
    mostbet mostbet mostbet.
    1985 300zx N/A - June 4 2012 Sold to Austin Irwin
    1987 2+0 N/A - March 19 2014
    1987 2+0 Turbo - May 6 2014
  • les_joey_paul
    les_joey_paul
    • 743
    #7
    This. Yes please. Let us know if you need a deposit or something to buy the material?
    My build thread (:
  • harwood909
    harwood909
    • 131
    #8
    I will start a thread when I find the best way to make them. Keep your eyes peeled!
  • reddzx
    reddzx
    Senior Citizen
    • 6440
    #9
    These are the dumbbell bushings correct?
    1991 Hard-body 2WD
  • z-flash
    z-flash
    • 423
  • G-E
    G-E
    Junior Member
    • 6320
    #11
    I used the early style tension rod bushings from the prothan kit, threw them on a lathe after freezing them overnight… drilling was the hard part
  • C.Gesler
    C.Gesler
    Member
    • 79
    #12
    Harwood if you need anything to get this going please let me know
    And thank you
  • C.Gesler
    C.Gesler
    Member
    • 79
    #13
    Harwood any luck on figuring out thies bushings
  • harwood909
    harwood909
    • 131
    #14
    Waiting for the quote from the salesmen at work, once I have that I can see if people are still interested. I chose to have them poured instead of machined so production will take a bit longer and price will be slightly higher than if I were to turn them on my own. The finished product will be much nicer and will have a similar appearance to pieces that come in Prothane kits.
  • reddzx
    reddzx
    Senior Citizen
    • 6440
    #15
    I'm down for one maybe two sets depending on price
    1991 Hard-body 2WD
