transmission bushings
joshers21Member- 95
I'll take a set!87 Turbo - http://z31performance.com/showthread…-turbo-rebuild
88SS - #767
88SS - #824 -
Reds89Senior Member- 318
Those bushings and window triangles are a sure shot.Cha iro
harwood909Senior Member- 131
Can anyone measure the O.D. of the steel collar that the bolt runs through? If anyone has it laying around that would be great. Otherwise I'll get the car up on stand and pull the mount myself to measure. I received a quote today and I just need to double check this dimension before I put an order through. Thank you1985 300zx N/A - June 4 2012 Sold to Austin Irwin
1987 2+0 N/A - March 19 2014
1987 2+0 Turbo - May 6 2014 -
It's not critical, there's plenty of bushing even if it was 3/4" tubing, as long as the ID is a fairly loose 10.5-11mm -
C.GeslerMember- 79
ParkerSenior Member- 966
I'm in for a set if they're still being produced.Zoey - 1987 Z31T GLL - HKS EVC / CM SS 3" turbo-back / Stance GR+
The bolt location in the pictured bushings is wrong. I have a set in great condition if you need a reference.Cha iro
Is this referring to my photo?Originally posted by Augustus Maximus View PostThe bolt location in the pictured bushings is wrong. I have a set in great condition if you need a reference.
As for progress of the bushings… Winter has struck early and very hard here in Wisconsin and I simply ran out of time to remake a sample bushing so I could confirm the fitment in the garage. The drawing I had of the original bushings I made was thrown away as I didn't expect to make them every again. Really the only thing I need is to confirm, for myself, that the through hole is the right diameter before I put an order in. This is important so the original steel sleeve can be reused.1985 300zx N/A - June 4 2012 Sold to Austin Irwin
1artworkzSenior Member- 1143
I have the molds and can make 4 sets at a time for anyone desiring a set of 4 bushings in the correct hardness, red. $40.00 delivered. Add $10 for Canadian shipping. Email me at gary.molitor@gmail.com
This spring I will be doing a production run of front and rear spring poly plus steering rack bushings. -
reddzxSenior Citizen- 6440
I'll take a set in red, PM me with payment details please
1991 Hard-body 2WD
I will email too. So we get 4 of those trans bushings but it only requires 2, that's what he's saying?http://z31performance.com/showthread…2-2-(-now-NA2T
My build thread (:
