How to use a Z32 ECU in a Z31 VG30ET with NIStune
ButterSenior Member- 1519
Axel kainModerator- 1221
you do realize you can get a precalibrated HPX for a Z32 spec MAF scale, right?Damn dirty angels....these cars!
sigpic -
Rick88ssSenior Member- 2433
Yeah I've seen it but haven't looked into the exact specs. It's probably more like a replacement instead of using an original Z32 maf which is said to be limited to around 500 whp and when using stock size z32 fuel injectors. I haven't bought it yet but so far I'm going with the HPX N1 that's good for over 700whp in a 3" MAF housing. It's in the Nistune drop down menu for MAF selection. Also going with 1000cc injectors.Originally posted by Axel kain View Postyou do realize you can get a precalibrated HPX for a Z32 spec MAF scale, right?Shiro #443
so far the limits of MAF's have been rumors, and bad ideas. regardless. I cant remember the exact scale, but I do know it is individual to the Z32 spec. I have one on my car, and need to get tuned to see what it is capable of! As well as ZcarGo's once i get the dead spot at 2500 figured out…
I thought the HPX in a 3" tube was rated at 1000, or 1300 hp or something outrageous. either way, cant wait to hear how this goes!Damn dirty angels....these cars!
sigpic -
On the PMAS-maf.com website it says that the HPX N1 is good for 830 whp in a 3" housing. More than plenty for me. Matt from Nistune has tried it on his R34 with an RB25DET neo engine and he said it works fine with a perfect idle and no drive ability issues. He tried it in a 3" housing mounted before the turbo in a draw through setup.Shiro #443
I had to redo my intake since I'm adding a MAF. Working on a cold air intake and also keep the hot radiator fan air away from the air filter. Here I made a template out of foam board. Then I'm gonna get it done in aluminum.
20150131_171343.jpgShiro #443
If you cut the front of that air box out, and punch out the rubbery plastic material that is between the top of the radiator and front bumper support, you can accomplish functional cold air induction.http://z31performance.com/showthread…2-2-(-now-NA2T
My build thread (: -
New parts for the new setup
Couldn't pass up the good deal.
20150205_212058.jpgShiro #443
Installed the new ID 1000cc injectors. I'm gonna run them with the Microtech first to check for leaks and see how well they work.
20150207_150003.jpgShiro #443
PulseCodeSenior Member- 1522
Got the flange for the Z32 AAC valve welded on to my Z31 gutted manifold.
Before
After
20150214_155146.jpgShiro #443
AAC idle valve painted and mounted. No leaks from the new injectors and fuel lines. I also filled the fuel tank with about 8 gallons of 93 octane since the flex fuel setup with Nistune requires an initial tune with 93 octane. Then drain the tank and fill with E85 and retune .
20150215_160505.jpgShiro #443
