How to use a Z32 ECU in a Z31 VG30ET with NIStune
  • Axel kain
    Axel kain
    Moderator
    • 1221
    #46
    I have to ask why you would mount it on the opposite side of the metered air piping? why not near the stock location so you can easily draw from the intake piping?
    sigpic
  • Rick88ss
    Rick88ss
    • 2433
    #47
    It won't fit in the stock z31 location. Right now it's not electrically hooked up and has 2 rubber plugs on the inlet. I need to connect the hose to the back port. (The one on the left with the black cap on it.)
    All I have to do is run a hose from the I/C pipe before the throttle body around the back of the engine to the Z32 idle valve. I already have some fittings welded to the intercooler pipe.
    Shiro #443
  • Axel kain
    Axel kain
    Moderator
    • 1221
    #48
    similar to the old AAC valve I guess, fix up a hard pipe, and run it with a 1/8" too, for that vacuum hose there too.
    sigpic
  • FlawleZ
    FlawleZ
    • 1971
    #49
    Excited to see your results Rick…but I'm curious where you've read somewhere the Z32 MAF maxes at 500? I made 545 on a Z31 MAF and it still had room to go. I've seen upwards of 700+ on a Z32 MAF.
    545 RWHP & 540 RWTQ
  • Rick88ss
    Rick88ss
    • 2433
    #50
    I see conflicting results but usually in the 500's. I'm sure that the 700+ must have been with a Selin MAF translator that effectively doubles the MAF capacity on a dual intake Z32.
    So to avoid maxing out the Z32 MAF and problems with reversion when you use a recirculating BOV, I'm just going with a PMAS HPX N-1 MAF.
    Like the one in the new Nistune videos
    https://www.youtube.com/watch?v=xVMJte7UOdA
    https://www.youtube.com/watch?v=9HbmYcZj-bg
    Shiro #443
  • boosted300
    boosted300
    • 195
    #51
    Originally posted by Rick88ss View Post
    I still have to modify it some. I can also connect a tube from the passenger side headlight bucket. There's a cold air setup already for the factory airbox.
    go with the setup I used to have bro....
    It's a combo of what les and you are saying…
    It's open in the front and it also has a hole in the side that draws from factory CAI location…
    you should also move it off center as there is a hood seam that runs right down the middle of this area and /I used it to form a seal around the airbox so that when the hood is closed, it only draws external cold(er) air
    (look at my old ass HKS Intercooler from 1989 lol)
    but back on topic, your fuel system is trick as hell, I can't wait to see how flex fuel works
    https://www.reddit.com/r/WeedInTheUk/comments/1t4be3a/cannabis_seeds_uk_law_is_it_legal_to_buy_cannabis/.
  • les_joey_paul
    les_joey_paul
    • 743
    #52
    I get what you are saying but I'd try and do it on the other side.... because you have that hot radiator hose right there.
    My build thread (:
  • boosted300
    boosted300
    • 195
    #53
    there's really not that much heat radiating from that small hose. I considered that initially and I held my hand near it at operating temp and you really couldn't feel much heat, certainly not enough to outweigh the cold air from the factory hole…but I suppose I could wrap the hose with heat shielding like I did with fuel lines…great tip!
    (sorry for the threadjack Rick!)
  • les_joey_paul
    les_joey_paul
    • 743
    #54
    Yeah a few degree makes a difference it would only make more radiant heat at a stop. Me being in Florida that hose gets HOT with engine warmed up. I'm going to have to investigate further how the headlight bucket ducts into the intake area.
    My build thread (:
  • boosted300
    boosted300
    • 195
    #55
    I feel ya…Rick and I are both in Miami
  • Rick88ss
    Rick88ss
    • 2433
    #56
    I'm gonna get it done in about 2 weeks. Waiting for income tax return.
    Shiro #443
  • les_joey_paul
    les_joey_paul
    • 743
    #57
    Ohhhhhh nice. Are you guys going to the auto combine meet on the 15th?
    Also I think I might try creating a duct on the driver side headlight similar to yours boosted300.
    My build thread (:
  • ShamWow
    ShamWow
    • 1905
    #58
    Ive been using that MAF for awhile with nistune and it works good.
    Why the change from running microtech to nistune? I bought a haltech to go the opposite direction
    "produce first.talk second."
  • Rick88ss
    Rick88ss
    • 2433
    #59
    I want the flex fuel setup. Also I want a more stock like running car when idling and with the A/C running. It seems like the Microtech is better for racing and cars without A/C. It does work with the ac but not smooth. No flex fuel with Microtech and support sux
    Shiro #443
  • Rick88ss
    Rick88ss
    • 2433
    #60
    Update:
    Finally got around to getting the air filter heat shield made. Also had a 1.5" tube welded on before the turbo inlet to recirculate the BOV since I'm using a HPX N1 MAF before the turbo.
    I still need to paint the heat shield and make a hole in the side to direct some cold air in from the passenger side headlight bucket.
    Shiro #443
