Megasquirt info
BLOZ UPSenior Member
- 2971
It would be more work to piggy back. You would have to add a MAP sensor and keep the MAF.
Using the CHTS is simple, it just requires using 3 value pairs from the FSM and plugging them in to TunerStudio.
Using TunerStudios VE table generator is sufficient to get it started and idling. That and just enter idle timing in to the timing map.
Any particular reason you want to keep the stock computer?BLOZ UP.com
MrFishHatSenior Member
- 505
http://www.diyautotune.com/catalog/54-m … 37d65eb498
This would make most MS installs even easier than before.
- 2971
MrFishHat wrote: http://www.diyautotune.com/catalog/54-mm-optical-trigger-wheel-for-nissan-l28et-or-vg30e-p-497.html?osCsid=ee0c2757685a3919fec75737d65eb498
It's just as easy, if not easier, to setup the OE wheel and use a basic trigger. The offset is 60, and then you just turn the distributor till the timing light matches MS.BLOZ UP.com
Black 89TurboSenior Member
- 495
[quote]BLOZ UP wrote:Originally posted by MrFishHathttp://www.diyautotune.com/catalog/54-mm-optical-trigger-wheel-for-nissan-l28et-or-vg30e-p-497.html?osCsid=ee0c2757685a3919fec75737d65eb498
You would need to wire up BOTH sensors to fully use that wheel. However, I'm running on just the 24-1-1 portion of that wheel. Timing is a bit more accurate.
You would think, but mine dont work like that lol.89' Turbo-R.I.P. (scrapped)
- 2971
Eh, whatever works. I think the VG is a prime candidate for MS3 experimentation. I'll be going that route sometime in the near future.BLOZ UP.com
- 495
BLOZ UP wrote: Eh, whatever works. I think the VG is a prime candidate for MS3 experimentation. I'll be going that route sometime in the near future.
Powered by Fund Solvaren.89' Turbo-R.I.P. (scrapped)
- 2971
Thought you had it running? You have a good wiring diagram of what MS pins are connected to what on the car?BLOZ UP.com
- 495
BLOZ UP wrote: Thought you had it running? You have a good wiring diagram of what MS pins are connected to what on the car?89' Turbo-R.I.P. (scrapped)
MyselfJunior Member
- 2
BLOZ UP wrote: It would be more work to piggy back. You would have to add a MAP sensor and keep the MAF.
No particular reason I want to keep the stock computer. In fact I'll like to get rid of it.
But I dont have any experience installing and using megasquirt or any other engine management system.
So Im a little scare to go full, not knowing what I doing and having no one to turn to if something goes wrong.
I was reading this thread a few pages back and someone mentioned that it was relatively easy to install it and have it running on fuel only.
But you think it will be better to just install the full system from the start??? (spark and fuel)
I have done some reading on megasquirt but still don't feel comfortable enough to attempt the full install. -
- 495
This is exactly how its wired. BUT there is no idle solenoids or anything of that nature.
- 495
[quote]Myself wrote:Originally posted by BLOZ UPThanks for answering
I have done some reading on megasquirt but still don't feel comfortable enough to attempt the full install.89' Turbo-R.I.P. (scrapped)
- 2971
Black 89Turbo wrote: This is exactly how its wired. BUT there is no idle solenoids or anything of that nature.
[pre]signal
|--resistor--- |
+12v[/pre]
That's a horrid diagram, but the resistor should be connected between +12v and the signal line.
Your coil looks right. So it idles, stalls what? It at least fires up… ?BLOZ UP.com
- 495
BLOZ UP wrote:
What's that resistor on the signal line connected to? It looks like it's just inline. It should be:
[pre]signal
|--resistor--- |
+12v[/pre]
Your coil looks right. So it idles, stalls what? It at least fires up… ?89' Turbo-R.I.P. (scrapped)
- 2971
High impedance injectors or low? Resistors?
I see just a couple pages back all your settings. Are those still accurate?
PM me.BLOZ UP.com
- 495
BLOZ UP wrote: High impedance injectors or low? Resistors?
PM me.89' Turbo-R.I.P. (scrapped)
